check engine light on already!!!
JennaLynn02
Jenna
Toyota Camry
my check engine light came on today!!! i got my bronco less than a week ago! here’s what ford pass says.
anyone else have the same??? bringing it in tomorrow morning.
Ford Bronco check engine light on already!!! 6717A057-CC3E-43CF-A8DF-E1BBA569D7C1
Drafting_Monkey
Dennis
N.E. Illinois
09 GT/CS, 20 Honda Insight EX & 19 Mazda CX9
Check for a loose battery connection. it could also be the Evap Canister Purge Valve which is part of Fords cap less fuel door system if I recall. I had an F-150 throw a cel light mostly in the cold months and it was due to that. If it drives rough or seems different it could be something worse. I always drove my F 150 with no issues and the light would turn off. Obviously with this being a new vehicle I would take it in to have Ford diagnose it. Sorry for your early Bronco woes my fellow 1/17er.🙁
Headsong
Mine came on as I drove away from dealer! Lose connection on sensor/broken tab... Waiting on replacement. Is light isn't flashing... You're on to keep going.
Odd Ball
Cali
HD Vett Mustang Jag 911 (2)450SLs VWcab Blzr Fiat
Fuel cap not on correctly?
Ducati1098
The FordPass description is just straight up generic. Just going to have to bring it into the dealer and have them look at it. Could be a hundred different things.
Ford Motor Company
Official Ford Account
Dearborn
Bronco, Bronco Sport
Good morning. Can you please send over a private message with your VIN and the name/location of your local Ford dealer? I would like to see what I can do to assist with your Bronco's engine issues.
Bemcnamara
Brad
Coeur d'Alene Idaho
2015 F56S MINI
I have the same thing going on. My code reader showed a "P0456 Evaporative Emission System Leak Detected". I cleared it and it came back a couple of days later. I have a service scheduled on 8/2. I had to call around to a couple of dealers. The first dealer told me they were a month out on check engine light repairs!!??
Ford Bronco check engine light on already!!! 20220720_162617
Ford Bronco check engine light on already!!! 20220720_162631
JennaLynn02
Jenna
Toyota Camry
my dealership told me they were 6 weeks booked for appointments & i said “i haven’t even had it for a week!!! you need to fix it today!” i took it there before they opened. the check engine light turned on yesterday when they were closed so i couldn’t make an appointment.
cowman
cowman
texas
ford
Mine did the same thing the other day.... My code reader showed a "P0456 Evaporative Emission System Leak Detected ... Hot in Texas right now... pushed the little flapper a couple of times on the fuel tank... cleared the code.... never came on again... that was 2 weeks ago...
JennaLynn02
Jenna
Toyota Camry
my dealership just called & said they fixed it! sounds like tbis was probably the same issue you had but they did say they replaced a part! so you may want to take yours in if you have time since it’s under warranty!
rtazz17
Connecticut
2022 Ford bronco big bend
Prolly cleared the code (aka replaced part).
Sweetair
2013 SHO, 03 Marauder, '69 S Code XR7 vert Cougar
I had the same P0456 code just come on on my 2013 Taurus SHO. I have a cheap Craftsman OBD reader.
The fix was getting a replacement Evap Purge valve for under the hood. Keep in mind that my car is 9 years old with 84k on the clock. Not sure why a one week old vehicle would dothis unless something popped loose. Good luck.
