Check engine light is on , Code P0C2C
Helomech73
Everglades
2023 Bronco
Everglades
Help,
Check engine light is on, Code P0C2C.
2023 Everglades 8600 miles.
Read the Code cleared it but it came back. Suggestions?
TX-Dennis
Dennis
Southern LLano Estacado
Bronco, Lincoln
That's a transmission pump code. Take it to your dealer for repair. Most likely needs a sensor replaced.
Jimmiee
Reno, NV
Chevy Silverado
This DTC indicates the transmission fluid auxiliary pump frequency is between 125 and 175Hz but has an invalid duty cycle, or the frequency is outside of the 125-175Hz range. This can be caused by a loss of power to the transmission fluid auxiliary pump.
Did you disable the Start/Stop feature? Does the Start Stop feature work when you come to a stop? Does the engine start right up and the vehicle take off normally?
Any other mods done? Any programming done?
Helomech73
Helomech73
Everglades
2023 Bronco
Everglades
Thank you for the reply. I press the auto start stop disable button every time I start the Bronco. It does work. When I leave the feature on it starts when the brake pedal is released and accelerates normally with no drive ability issues. Other than a K&N airfilter and a curt trailer hitch with plug and play wiring harness, and ford performance air/oil separator it is stock. No tuning has been done.
Jimmiee
Reno, NV
Chevy Silverado
If the case connector on the transmission is wet from ATF seeping through the plug it can cause this code. I would take it in since it's under warranty and have the dealer check it. There may also be a software update for this as well.
