Cheap ditch lights installed.
orion
Jeremy
17' F-250, 17' Explorer
Why that? It’s a light nothing to it.
So you upgraded your headlight switch to dual fog switch and then hooked up your new relay to what, existing wiring or switch output? I thought these new vehicles were all run off of can bus and you had to connect to existing wiring? If existing wiring, where did you tap into? If just the switch, let us know how!!! I may need to buy myself a dual fog switch after all...
‘21OBX
‘21OBX
Ken
90Bronco19
2022 bronco outer banks
I used a relay like you normally would battery, fuse then used the rear fog light wire to trigger the relay. In the fog light switch thread there are wire diagrams and connector pin outs. It’s either white/blue or blue and white wire. I cut it under the rear door sill trim long enough to run through the firewall and hook to the relay.
Beaver24
Missouri
2018 Juan Fitty
I took off the part of the mirror that says accessory ready. And just lifted the edge of the cowl panel.
I did the same.
