Charging/Center Console 3D Print STL File?
JBlanco
Julio
Charlotte NC
I want to add a charging pad to my base Bronco and want to know if anyone here has an STL file of the charger pad. TIA
Ford Bronco Charging/Center Console 3D Print STL File? IMG_20241103_104842084
JBlanco
JBlanco
Julio
Charlotte NC
smelly
Massachusetts
2022 2DR Black Diamond 7MT
Automatic, thanks for the link, but mine is a base and doesn't have the option of the rectangular removable base below the rubber mat.
As long as you don't mind hacking up the trim pieces, you could always remove it, 3D print this piece and mark/drill a 2.5" hole in the center with a hole saw:
https://www.thingiverse.com/thing:4936062
WheresMyBronco
Los Angeles
2023 Badlands
Dang, if I had that piece in my Bronco I'd mock it up for you. Depending on what you need I might be able to make something close enough for you to use
