Changing Interior Air Vents Tab Color?
Ground_zero298
Scs michigan
Someone on Etsy was selling them, saw them a few weeks back, but poof they are gone now.
Ford tends to get mad when you don’t have licensing. Plus you get paid for turning business in. Bunch of crooked law firms out there that just go after people “bootlegging” products.
PonyStable
JT
New York
2016 Mustang
I got a set on EBay and I'm guessing that it was from the same seller that was on Etsy. I got a message from him today that another client told him that they warp after the heat has been in high for about ten minutes so I'm guessing that's why they vanished. He was great to deal with as he reached out to me and offered a refund.
hopefully he can find a plastic that is more durable and heat resistant.
Murph914
Franklin, MA
2008 F-350 reg cab srw v10 manual
I’d love to swap out the bright orange for red or pretty much any other color. I’d just assume get them from Ford even it’s the whole finned assembly. That little nub gets hotter than a $2 pistol with all the heat coming from the dash at full blast. I put the little cheap stickerfab stickers on the inside bit and that really did a good job to tie it together. I’d recommend folks try that first before doing anything drastic.
Papa Smurf
Jax, FL
‘23 Bronco WT. ‘23 Maverick. Hybrid. '23 Rav4
I got the same message!
djp
djp
Idaho
'22 Badlands 4dr || '21 Bronco Sport BigBend
mtap
Mervin
Cape Coral, FL
Toyota Tundra, Hummer H3, Harley Sportster
Stickerfab just released theirs…
Ford Bronco Changing Interior Air Vents Tab Color? E57C9FBD-AC6E-43B7-A59E-9647FF72D667
Ford Bronco Changing Interior Air Vents Tab Color? 1034DDF1-8BDF-4FBF-AC58-FC5C7F394F73
Ford Bronco Changing Interior Air Vents Tab Color? 0C81CE6A-57C2-479E-98BB-ED9F1F25F02C
Ground_zero298
Scs michigan
that looks awesome! You should sell the vent clips!! If you decide to, sign me up for a HPR color! LOL
I’ll have to see if I can buy vent clips separately. It honestly takes 30 seconds to paint one.
Diydner
Diydner
Ryan
Winter Springs, FL
Ram 1500
If you know of an easy way to remove them, I wouldnt mind shipping them to you. Could you match hpr?
Skott
Missouri
2022 Bronco
As promised.
= 0005 wicked red/4050 gloss
Splash of blood red candy
4011 reducer
Two questions.
1. Can you share the link for those phone holsters on your lower grab handle? That's probably the most elegant solution I've seen yet.
2. Why do you have/need two phone holsters attached to the grab handle?
Thanks!
Ground_zero298
Scs michigan
Skott
Missouri
2022 Bronco
Ground_zero298
Scs michigan
Thanks buddy. I appreciate it.
Do you use the rubber corner holders, or does the side grabbers hold it steady enough for daily (on-road) driving?
Side grabbers are more than adequate. I’ve never used the corner holders. I ran the same setup in my x3. Never had a phone fall out.
