Changing front and rear diff oil on basesquatch
Rush4th
Donny
Norco, ca
2021 bronco
Pardon my ignorance, but this will be the first time I change the oil in both diffs. Can someone explain the torque needed for the cover? I found 177lbs and 25. What does that mean? I tried looking it up, but couldn’t find any info. Also, the book says that the plugs are non reusable? And can someone confirm the oils that that need for both the front and rear?
Thanks!
My guess is you have one source in inch lbs (177) and one in foot lbs (25) - the two numbers you have don’t exactly agree but are both in the same ballpark, and it wouldn’t be the first time you have a different spec from Ford and one from the OEM (the oil spec is the similar, for instance)
Bigger risk of going too tight and damaging the gasket than too loose - where you would probably notice an oil drip before anything catastrophic occurred. The gasket would likely hold just fine with just every other bolt in - but don’t go trying that out.
CarbonSteel
Colorado Springs
2023 Carbonized Gray
Thanks!
I forgot to answer the other questions.
Ford specs an initial torque value and then a degree to turn after initial torque value. Just tighten to between 22 and 25 foot-pounds and you will be good.
The drain plugs are completely reusable. There are nothing more than standard half inch NPT pipe thread plugs.
The gasket is also reusable multiple times unless it is damaged.
Finally, I would run 75W-140 in both axles as Dana specifies. If you so choose, you can also follow Ford's recommendations but you're not going to find off-the-shelf oils to meet the viscosity they specify in the owner's manual for the rear (75W-85), it is a Ford only oil.
Rush4th
Donny
Norco, ca
2021 bronco
Thank you all for the info! You guys are awesome for clearing that up for me.
Shoukd I use any lock tight on any of the bolts?
Aonarch
Jack Hoff
MT
I'm glad you asked for torque values, because overtightening NPT plugs can crack housings on any car.
