Chalk test
Stonetree
Stonetree
Ron
Pittsburgh
2021 Bronco Wildtrak
My MT Baja Boss AT's (37x12.5x17) sweet spot is 32/33. You're not going too low. I called and spoke with MT (very helpful btw) and they did calculations based on old tire load rating/size, vehicle weight, new tire size (37's), etc and said for me to "start" at 33 psi. Haven't chalk tested and won't as they are just right for my comfort level. Good luck.
That's good to hear!
Aonarch
Jack Hoff
MT
‘23 Bronco OBX 2DR Lux 2.7, ‘24 V60 Polestar
jzweedyk
Moab, UT
2025 Lincoln Navigator
Does anyone have the load inflation table for the 37x12.5r17 Load Range C KO2? I can't seem to find it, and BFG has been less than helpful.
kodiakisland
Arkansas
This is exactly why I do not like Load E tires for example on a light SUV.
Load rating has nothing to do with proper PSI, only max PSI.
kodiakisland
Arkansas
It’s the same as any other brand tire. The one I posted above from Toyo works.
jzweedyk
Moab, UT
OK, Thanks. It only goes down to 25, but even at that those tires are rated more than the Bronco weighs. So for my 2 door 28 PSI is fine. I will do 28 around town and 35 on the highway.
kodiakisland
Arkansas
You do have to factor in that is a static rating. For on highway you want around 1.6X static rating. There is an official conversation rate if you can find it, but I go with 1.6.
Yeah, 28 is fine.
FoxFour281
Kelly
Central Valley, CA
02 Mustang GT, 02 Expedition EB
Alanp970
Alan
2023 4 Door Base Sasquatch Hardtop
I had 35x12.50 17 BFG KO2’s E’s on my Gladiator and found about 28 psi gave a good contact patch. I had almost 55,000 miles on them when I traded it in on my Bronco and they had a lot of tread left and never gave me any trouble
Silver-Bolt
Bill
Eureka, MT
I was testing this out today. Seems to be under 35 triggers the low psi error light.
I am down to 32psi on the factory tires with no warning lights. It even shows 32psi on the dash.
Aonarch
Jack Hoff
MT
Interesting. Maybe it does auto-adjust over time.
You can adjust with forscan, but you are correct, it does auto adjust over time.
