Gypsy
Maria
Finished her up with this hood from Cervinis. Painted from the manufacturer spot on fit and finish. Took some time but worth it
I normally like Safari Bars but I must admit your Brush Bar is the best I have ever seen. I love the whole setup of your Bronco, especially the hood.
ttt123
brian
Lapeer mi.
Bronco, GMC evolution, Chevy corvette
That is really nice looking !! (y)
cj91
TX
Worth getting the underside painted or not?
Nibroc99
Corbin
Rochester, MA, USA
www.corbonthecob.com
2022 Wildtrak: The WildeBeast
Yooo I just bought that brush guard, waiting for it to arrive!! I have to ask - is the mesh/grille easily removable? Is it bolted on? If not I'll be cutting it off from mine regardless, just curious!
keester
Drew
Illinois
any word on this?
broadicustomworks
Hanging Rock, North Carolina
The Mesh grille comes uninstalled.
It attaches with about a dozen of these really crappy small self tappers (mainly because it is tapping into fiberglass).
If one did not want it installed it is as simple as not installing it.
Nibroc99
Corbin
Rochester, MA, USA
any word on this?
Yes! I'm glad you reminded me to send an update. It came with the bottom-center grille portion installed with some black hex bolts and black split washers. I ordered mine from Elite Truck's website. It was easy to remove and they even included the alan key. Idk what the other fella is talking about with the self-tappers - the grille on mine was installed with seemingly brass or nickel rivnuts for the stainless bolts to screw into. Ignore the terrible placement for my front plate - I was awaiting some pipe clamps so that I could attach the license plate to the bottom bar of the brush guard.
To attach the radiator support on the passenger side, I used a drill to cut the rectangular hole into the plastic trim piece behind the grille for the support to slide through. Basically made a bunch of holes with the drill and then pushed sideways to break the rectangle free.
Ford Bronco Cervinis Stalker Hood installed 20250514_090354
Ford Bronco Cervinis Stalker Hood installed 20250514_090500
Ford Bronco Cervinis Stalker Hood installed 20250505_140557
Ford Bronco Cervinis Stalker Hood installed 20250514_090324
Ford Bronco Cervinis Stalker Hood installed 20250514_090452
Ford Bronco Cervinis Stalker Hood installed 20250514_090254
Ford Bronco Cervinis Stalker Hood installed 20250514_090222
Ford Bronco Cervinis Stalker Hood installed e9b34c20-4987-4aa5-925b-e653158baefa
Nibroc99
Corbin
Rochester, MA, USA
What are you talking about with the fiberglass? The thing is made of steel - even in the name, "Steelcraft heavy duty brush guard." Mine has no fiberglass on it and the mesh grille in the bottom-center came installed using rivnuts and stainless allen head bolts holding it in place. Curious if we're talking about the same product.
broadicustomworks
I was talking about the fiberglass Cevinis hood the thread title was about.
I mistakenly thought the question was about the grille inside the scoop on the hood.
Nibroc99
Corbin
Rochester, MA, USA
Ohhh that makes total sense. Thanks for clarifying. :)
