Center console arm rest extender
Lauraleighx3
Laura
Maine
2016 Jeep GC
Am I the only one with short forearms? I have a manual and whenever I'm in the forward gears (1,3,5), my elbow just barely touches the center console to rest on.
Is there any solution to extend the center console further forward? Sliding would be nice, but not necessary. I haven't seen anything posted on here that I could easily find.
9nate9
Nate
Massachusetts
1974 Bronco
Did you ever find a solution, cuz I’m feeling your pain, was looking for a sliding solution maybe?
Fordified1
Bob
Mid South Texas
Seems like something @Mabett would come up with.
Tybh88
Tyler
Why isn't this a thing still? Only thing I missed on my fiancé old crv.
CalvinT
Calvin
Phoenix, AZ
Why rest your arm on the console? You should have both hands on the wheel.
The original post is a bit old but -
I don’t know of any console extension, but if you get an aftermarket shift knob that is a bit taller/longer it has a similar effect and there are a lot of those
CalvinT
Calvin
Phoenix, AZ
I thought a bit more... In general it's not a good idea to rest your hand on the shifter. It can cause wear on the shift forks and maybe other parts of the transmission.
Will it do that in a cable-driven shifter?
CalvinT
Calvin
Phoenix, AZ
The shift forks are inside the transmission. They move the gears from one gear to another. On some (older) transmissions putting pressure on the shifter can increase gear wear. I'm not sure that's a problem with newer transmissions.
