Cargo box for Trailrax half-rack?
Kmautah
Kevin
F-150 Lariat, Tesla Model 3, MB Sprinter Van (170)
Has anyone mounted cargo boxes to a Trailrax half-rack? I bought and installed the TrailRax half-rack a couple months ago. Solid rack, with good potential. It solved my immediate need of mounting a ski rack, and I will likely get the Pax Rax at a future point as well for carrying spare fuel, water, etc. Looking now at adding some cargo boxes for additional storage on camping trips, not doing any serious overlanding, but with 4 passengers there is not a ton of room for gear (even with the super-spacious 4 door ;)). @TrailRax any suggestions here for cargo boxes that would specifically fit the half-rack?
Ford Bronco Cargo box for Trailrax half-rack? IMG_2333
TrailRax
Lux Sponsor (Level 2)
TrailRax
Woods Cross, Utah
www.trailrax.com
2023 Bronco Badlands
Hi Kevin,
The bronco looks awesome! This case should fit pretty perfect on there! You just may need to move the crossbars into the slots for proper spacing
https://www.pelican.com/us/en/product/cases/cargo/bx140r
Thanks,
CCCycleguy
Denver, CO
Bronco 4 door
We have several of these and LOVE them. They are waterproof, with lots of organizers inside. they lock together really well. I found they are TONS cheaper than the official overland boxes and can't find any fault in them. they stand up to any weather.
Have two of these:
https://www.acmetools.com/milwaukee-packout-deep-organizer-48-22-8432/045242600694.html
Two of these:
https://www.acmetools.com/milwaukee-packout-large-tool-box-48-22-8425/045242505340.html
One of these that we keep inside for big things and stack the others on to roll around the campsite:
https://www.acmetools.com/milwaukee-packout-rolling-tool-chest-48-22-8428/045242600670.html
And also have one of these, although I tend to keep it inside most of the time, since it doesn't tie down so easily.
https://www.amazon.com/gp/product/B0C15QDNY9/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1
WalkerTR
Tony
Florence, Alabama
2018 F150, 1978 Bronco
The closest case that I can find for my half rack is the ROAM 66L. Like Pelican they are pretty pricey but solid. 31"x18.5"x10.8. I am considering two. (Hers and Her other one)
adcam
Mando
2025 Stroppe
Roam 95L fits as well.
JerryG
Rich
NY
Ford Bronco
Trailrax half-rack with Roam 66 boxes
Ford Bronco Cargo box for Trailrax half-rack? c362f5b209ce0b34acf896e633c6a7ea
RJones
Ryon
Dallas
2023 Wildtrak
Nice setup!
Are you able to easily remove the rear roof section with the half rack installed?
Would you be able to add on and upgrade to the full rack from the half rack?
JerryG
Rich
NY
Ford Bronco
Nice setup!
Yes to both.
Something Wild
KC, MO
2023 Badlands
Hi Kevin,
Thanks,
@TrailRax Do you have any issue with the mounting hardware (specifically the T-Slot nuts) that Pelican sells? The smaller size doesn't seem like it would have enough bite within the T-Slot rail. The large one is too big to fit in the slot. Was looking at mounting the BX140R in the next couple weeks for a trip.
Ford Bronco Cargo box for Trailrax half-rack? 1741019026327-us
Ford Bronco Cargo box for Trailrax half-rack? 1741018807271-st
TrailRax
TrailRax
Woods Cross, Utah
www.trailrax.com
The small ones work. If they are the same pieces that we have used from 1-2 year old mounting kits that they sell, which looks to be the case, it should work. We have some of these mounted on display racks in our show room.
jclark
Jeanette
Mid-Michigan
Do you have a photo of the Roam mounting brackets mounted to the rack without the boxes? I'd like to see where you placed them on the rack. TIA
Dugout
Joel
ETX
24 Bronco
Ford Bronco Cargo box for Trailrax half-rack? IMG_1559
Ford Bronco Cargo box for Trailrax half-rack? IMG_1562
Roam 83 L with tie downs works as well.
SillyPosition
Silly
Israel
None
Do you have a picture how it works out? 95L will stretch from edge to edge or can the rack accept the 128L?
Also, does 95L works well with their quick-release mounts?
the 83L is actually wider than 95L, why did you choose it instead?
Also how does it works out with the straps? Is it really secured without moving around while offroading?
Dugout
Joel
ETX
24 Bronco
it was really secure. Texas to Montana no issue.
Ford Bronco Cargo box for Trailrax half-rack? DJI_0009
I’ve updated my setup to Roam brackets and 95l cases. Long ways work better on top.
Ford Bronco Cargo box for Trailrax half-rack? 1779382552318-is
adcam
Mando
2025 Stroppe
I don’t have my 2021 BL anymore, but the 95L fit edge to edge. Trailrax website only mentions the 83L and 95L for Roam products that are compatible.
