Cargo area side panel diagram / sub rattle
Dazoman
US
FE
Need to remove the cargo area side panel that covers the sub so I can add some dampening material and tighten it up. Sub rattle is pretty bad with all the different modular plastic in the back. Couldn’t find anything via search and won’t just start yanking on plastic anchors without a good diagram. Has anyone seen anything published yet?
Holliday
Justin
Durham, NC
2021 Bronco Badlands
@Dazoman I just got my Bronco with the B&O sound system last week, and I think I have the same rattle but I can only hear it on certain tracks with the right low end bass frequency. Some songs sound just fine loud but others it is very apparent. Glass Animals - Heat Waves is a good example. Did you find a solid solution?
JAC
Joshua
Oregon
2018 Toyota Tundra; 2020 Acura RDX
Here's the rear trim removal... should help so you can add dynamat or some other sound dampening.
Holliday
Justin
Durham, NC
Thanks for that. On mine with the panel on, there's a spot on the bottom edge of it towards the front a bit that has a lot of flex.
I'm not in love with the thought of having to remove that, honestly. In older vehicles, it seems like I often manage to break a clip...
Anyone else hearing the same thing from the sub?
Anyone else already remove that panel and add anything?
JAC
Joshua
Oregon
While I haven't taken delivery nor do I even have a build date... I did spec my BL with the Lux. That said, I visited a local dealer and spent a little time messing with the B&O system.... Depending on song (everything from classical to metal to R&B, electronic) I did hear a good rattle from the rear sub.... I will be removing the back panels and installing Dynamat to resolve the body noise. And look to see what space I have to update the sub at a later date.
There was another post here (somewhere) a member recommended sound deadening to do the same and also help improve sound.
Enjoy your Bronco, Cheers!
Holliday
Justin
Durham, NC
Thanks! Yeah I tried a couple different searches and couldn't come up with anything other than this thread. For anyone else following along, we're not talking about anything crazy on the settings or super loud volume.
Default settings and not maxed on the volume. The B&O system isn't bad overall but this is particularly noticeable. That being said I love my Bronco.
Dazoman
US
FE
Thanks man!
  • Like
Reactions: JAC
Dazoman
US
FE
I pulled my rear panel partially off (will remove the whole thing now). Looks like it is where the panel contacts the sub itself. There’s some cheapo foam there but that’s it…. Will circle back w more now that I can pull the whole panel!
leviticusw
Levi
Sandy, UT
Hyundai Genesis, Isuzu Trooper
Can I get a part number for the sub? Does anyone know if It's an entire different side panel if you don't have the LUX? I am NOT going to use an aftermarket sub for my ride.
Thanks for the help.
OBX - CYBER ORANGE - HIGH PKG - SAS - 2.7
Mango&Moose
SE USA
Scion xB / Toyota Sienna. RIP my 96 Ranger Splash
Love to see some pics uploaded from anyone taking on this endeavor. I'll likely have to do the same when I get my Bronco in three years :cautious:
Theherofails
Thomas
Phoenix
I have this exact rattle.
I'll make a post if I find the solution. Wish me luck, I'm going in raw.
Bearcat1
Travis
2017 Expedition Limited, 2006 BMW 330xi
Nice removal instructions! Curious where you found that document. Is there a Bronco manual somewhere that has all of those kind of write-ups downloadable on the web?
Tortuga353
Laguna Beach, FL
Anyone succeed with this? Plan to attack this weekend.
Daktari
Oliver
I get a bit of a buzz on some songs, anybody have a link to the right dynamat stuff to buy? It's not exactly cheap and there seem to be different kinds, I know nothing about sound deadening materials. Would like to fix that buzz eventually.
