Calm Screen??
RaptorAU
Chad
Auburn, AL
2024 Bronco Raptor
Quick question is there a calm screen on the instrument cluster? On my F150 Raptor(23) I had it and it was really nice. Is this something that exists or can be programmed w/ Forscan possibly?
RaptorAU
RaptorAU
Chad
Auburn, AL
2024 Bronco Raptor
Not in my bronco currently, but I’m pretty sure you access that through the steering wheel controls/menu
Man I've looked everywhere. It's so weird they would remove that from the Bronco cluster
RaptorAU
RaptorAU
Chad
Auburn, AL
2024 Bronco Raptor
There is a calm screen on the instrument cluster. You can also turn off the display on the infotainment screen. Both are standard settings that don't require forscan.
I've looked and can't find it anywhere on the settings. It was easy on my 23 F150 but it's missing from the settings on my Raptor.
Cav427
Oklahoma
2019 Mustang 5.0 6 Speed, 2024 Bronco Outer Banks
Not sure about the Bronco Raptor, since it has a different display than the other trim levels. I Have it on my 2024 OBX, All it really does is eliminate the far right display above the steering wheel. I like the boost gauge or mileage gauge displays, although I sometimes use the Calm Screen.
All Calm does on the instrument cluster is remove the info from the really tiny right-hand window. But it does exist, and you can add it to the MyView menu for quick access.
The digital Speed/Tach remain.
There is also 2 versions on Sync - one where I think it just shows the time, and another where it turns the display completely off. They are both buried in Settings -> Screen. There is a shortcut if you are able to tap the Wifi/Notification icon, but on my 8" screen that's hard to hit while driving.
RaptorAU
RaptorAU
Chad
Auburn, AL
2024 Bronco Raptor
settings - display - calm screen / screen off
That's for the infotainment screen, I'm referring to the instrument cluster.
RaptorAU
RaptorAU
Chad
Auburn, AL
2024 Bronco Raptor
I swear they just left it totally off of the Raptor. On it's cluster calm just puts the model of the vehicle in the middle. I found it quite nice on my F150 Raptor
BigHoof
PA
Ram 2500
The cluster does have it but they are referencing the regular Bronco, not the Raptor which is completely different.
BigHoof
PA
Ram 2500
I believe the setting on the regular cluster in under the MyView section. Maybe look there. Should be things like MPGs, Power Distribution, Boost, that's where the calm screen in on the regular cluster.
Cav427
Oklahoma
Ford has gotten awfully weird about trim levels unfortunately. I have found myself sitting in the Bronco on two occasions trying to figure out Sync 4 and other features. Hope you find it!
RaptorAU
RaptorAU
Chad
Auburn, AL
2024 Bronco Raptor
Yeah it's so weird. I'm gonna mess around with Forscan and see if I can unlock it there. If I do I'll report back
Cav427
Oklahoma
I'd like to get Forscan and a OBD adapter. Please do report back, I am curious.
