Bumper Trim Replacement License Plate bracket
NJOffroad55
New Jersey
Telluride
I found a vehicle I like to find out a front license plate bracket has been attached and part of that seems to require two holes in a trim piece below the grill and above the bumper.
does anyone know how to find this part number (have been trying with minimal success) and if you need to take off the bumper to access?
thanks in advance
RagnarKon
Ford Bronco, Escape, Focus
M2DZ-17232-AAPTM
It will not come painted, and yes, there is a fair amount of disassembly to access it.
RagnarKon
Oh, I just realized this was in the Raptor forum.
The Raptor part is N2DZ-17232-ZAPTM
Also comes unpainted.
NJOffroad55
New Jersey
Telluride
Thank you. Same part for realtor? Found a build I really wanted but has two holes in bumper for the license plate unfortunately.
thank you. This is very helpful. Doesn’t seem all that hard to take off bumper?
RagnarKon
No idea.
On the normal Bronco it's fairly easy, so I would assume it would be fairly easy on the Raptor as well. You may also have to take apart part of the grille/headlights to get access to the brackets—not sure.
If you didn't want to buy a whole new trim piece, there is also these things called Bumper Plugs. MUCH more economical than buying a new trim piece and paying someone to paint it.
NJOffroad55
New Jersey
Telluride
No idea.
Yea saw those. Can’t believe the dealer drilled into the trim. But it is the exact spec I have been looking for…
RagnarKon
Believe it or not, they're actually supposed to drill into the trim piece. That's the official Ford-approved license plate mounting location.
If you look at that trim piece there is actually two little dimples in it to show dealerships exactly were to drill.
(Borrowing a photo from @Roger123's Bronco).
Ford Bronco Bumper Trim Replacement License Plate bracket 1710598423613-j8
NJOffroad55
New Jersey
Telluride
Yea. but most raptors I have see the dealer leaves them off. Seems there are a few aftermarket options that can use the exiting bolts etc.
Johnny Mo
Westchester County, NY
teachu2shoot.com
@DV8offroad makes a great one (yes it is already angled to follow modular bumper lines) - needs some spacers to fit Raptor but all items easily sourced on Amazon. Also - I installed rivnuts to make it a cleaner attachment than nut & bolt.
Ford Bronco Bumper Trim Replacement License Plate bracket PXL_20230701_001518121 (1)
Ford Bronco Bumper Trim Replacement License Plate bracket PXL_20230701_001524655
Ford Bronco Bumper Trim Replacement License Plate bracket PXL_20230903_180939034
Ford Bronco Bumper Trim Replacement License Plate bracket PXL_20230903_180925207
DewarT
Todd
I used the same bracket and picked up new bolts and plastic spacers at Lowe’s. Looks far better than the stock location And bracket
BBoyM3
Robert
San Antonio, TX
2015 Toyota Corolla LE
Awesome solution. Do you have a list of the parts / part numbers that you used (spacers, longer botls, rivnuts, etc.)?
Johnny Mo
teachu2shoot.com
https://www.amazon.com/gp/product/B09ZTVHWHX/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1
https://www.amazon.com/gp/product/B07D7DMLBB/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1
Pretty sure these were the bolts - but I may have used something else - easy enough to take the existing Bronco Bolt to home depot and get it 1/2" or so longer
https://www.amazon.com/gp/product/B0BWY22SWS/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&th=1
For license plate into the rivnut:
https://www.amazon.com/gp/product/B09DL4S31P/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1
To cover the rivnut back end so it doesn't rub on bumper:
https://www.amazon.com/gp/product/B0B4G1F84B/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&th=1
BBoyM3
Robert
San Antonio, TX
