Thurmy7
Kevin
Fullerton, California
Suburban, Tacoma, Patriot
Lots of nice looking Broncos on here, so I had to add a pic of our Rapid Red and matching Carrera. It tows great, but you've got to be careful with the turbo on any long grades or it will overheat.
Ford Bronco Broncos Pulling Trailers Pics - Add Yours 20220529_140847
RunninRiot
Brock
Boulder, CO
2021 Bronco Badlands
Ford Bronco Broncos Pulling Trailers Pics - Add Yours 23CF9289-A908-48A6-AC55-F6FF132E14A0
We left the house behind and are 6 days from living in the 2015 R-Pod 178 full time traveling the country. Trailer weighs 2,900lbs with all the equipment and solar added. We carry 350lbs of cargo divided between the Bronco and the trailer.
JRod Ford
Oregon
07 Ford Explorer Sport Trac
Got my 6x12 cargo trailer with folding bunkbeds, stove, fridge, and cabinets. The set of bunkbeds folds up out of the way so I can fit my Yamaha grizzly in there for hunting and dune trips.
Ford Bronco Broncos Pulling Trailers Pics - Add Yours 20220208_114123zoomed
SigSauer226
James
1965 Ford Mustang Fastback, 2011 Ford Mustang G
Starting a thread dedicated to Broncos pulling trailers. Post up your ride and whatever type of trailer you're pulling. Work or play.
My 2DR with my M416 trailer. Just on a quick test of the new trailer light wiring I had installed. Real work comes this Friday and Saturday when I'm going to do some service project work, so the trailer will haul supplies in and debris out.
How did you mount that spare?
NC_Pinz
NC_Pinz
Central NC
2022 Ford Bronco OBX w/ Squatch, 1975 Ford Bronco
The previous owner from my 4x4 club mounted it. I think he used a Jeep YJ mount bolted to the front. Works well and puts some much needed weight toward the front of the trailer.
luvtofish
Dan
Kansas City Area
2012 King Ranch F150 Supercrew.
Tow off road quite a bit.
Where did you get your adjustable hitch? I have a rockwood ESP I'll be pulling once my Bronco arrives. The dry weight of my camper is 2950. How did your camper pull?
KnoxGnater
Nat
Knoxville, TN
1934 Ford Roadster Pickup, Bronco Badlands
Nothing crazy, just camping gear and loads of tree trimmings on my Utility trailer. Can't even tell its back there.
Ford Bronco Broncos Pulling Trailers Pics - Add Yours Cam
Bucker
Neal
El Dorado Hills
2021 Base Sasquatch
Hitch thru Amazon. Tows great. No issues at all. Just need the longer shank to clear the spare.
Murph914
Franklin, MA
2008 F-350 reg cab srw v10 manual
5-1/2’ x 10’ Tractor Supply trailer. 5-1/4” drop hitch.
Nothing fancy, but needed something to replace my old truck’s ability to haul the big & uglies. I figure it won’t take too much weight to make the trailer level with the soft suspenion
Ford Bronco Broncos Pulling Trailers Pics - Add Yours 49EAD885-CC2A-42B1-B4AF-75C59D837C01
El Jefe Texas
Austin
2021 Ford Bronco Badlands, 1972 Bronco
So a while back I posted asking about pulling an Airstream Basecamp (about 2,680 dry weight) and got a ton of mixed feedback from some people saying no way to others saying no problem... now I've found this trailering thread and it looks like a lot of people are trailering with no issues. I'm looking into a sway bar and the Curt wireless brake controller... any other suggestions?
RunninRiot
Brock
Boulder, CO
You’re on the right track. We looked at a basecamp too but wanted something a few feet bigger since it will be our home. We use a friction sway bar. There are a number of different controllers and 7-way connectors that will work. Curt, redarc, tekonsha, etc. Due to time constraints we went to UHaul which has their own brand of stuff. We opted to not use a weight distribution system as they add another 40-50lbs to the tongue and would have put us over.
