killaz05
Anthony
Rockledge, FL
2021 Ford Bronco Badlands 2.7 Sasquatch
Ford Bronco Broncos Pulling Trailers Pics - Add Yours 272621947_3256110817951559_3902903856420222385_n
Ford Bronco Broncos Pulling Trailers Pics - Add Yours 272827164_3256110847951556_4573148510960332673_n (1)
rented this RV. This weekend I am renting a different RV and will post those pics
NC_Pinz
NC_Pinz
Central NC
Nice. What was the weight and how did it pull?
killaz05
Anthony
Rockledge, FL
The dry weight was 2950lbs. It towed great, no issues whatsoever. I purchased a curt wireless brake controller for the trailer I am renting this weekend. I think between the brake controller and maybe a weight distribution hitch with anti-sway, the Bronco should be able to go cross country with an RV this size
Djstang2011
Darrell
Reading, PA
2011 Mustang GT, 2021 Bronco Badlands 2 door
Last month I towed this enclosed 5 x 8 trailer from Reading PA to Myrtle Beach SC with no issues. Furniture, Boxes, etc. It was packed tight and I assume weight was around 3000 lbs. but I didn't weigh it. Bronco handled it like a champ, no problem at 75mph, averaged 14mpg for the trip.
Ford Bronco Broncos Pulling Trailers Pics - Add Yours IMG_3902
killaz05
Anthony
Rockledge, FL
Ford Bronco Broncos Pulling Trailers Pics - Add Yours 280754656_142919148315465_8823602307979598428_n
Ford Bronco Broncos Pulling Trailers Pics - Add Yours 280709015_142919171648796_3474766217797941382_n
So, I have been getting into RV camping this past year and love it. This unit I rented, and I am looking into purchasing this model for myself. at $14k new it is great for me and my two dogs. The trailer weighs 3,000lbs and pulls great. Better than the one I had before but I will attribute that to the hitch setup. Before I was running a hitch extension which I learned is a no-no. I am running an extra-long hitch which doesn't affect the towing capacity like an extension does. So much less sway and much more confident. Also added a Curt wireless brake controller which worked very well. I think if I were to run this setup cross country, I would get a weight distribution just to even the ride out and be extra safe.
Wildtrak0210
Josh
Westerville Ohio
2011 Nissan titan
Ford Bronco Broncos Pulling Trailers Pics - Add Yours 7F09E5AA-3045-4F55-BDD2-D58849933AB6
Firstbtime out for the season longer hitch on order to avoid having to remove the spare overal rows power wise better than my old Titan I traded in suspension is quite a bit softer, so it has a little sag in the back new hitch will have less of a drop so it may help a little
bronco_billy
Indy
Crown Vic
I don’t have my bronco yet, but I’m running a similar trailer weight with a 2012 Dodge Caravan. Using the Curt wireless controller as well, I just upgraded to an Anderson weight distribution/sway controller hitch. It’s a little bit expensive but it is well worth it. If I ever get my bronco, that’s the set up I’m going to use. Very glad to hear the Bronco is having no issues pulling a 3000 pound trailer.
Jason F
Grove City ohio
Ford Mustang
Starting a thread dedicated to Broncos pulling trailers. Post up your ride and whatever type of trailer you're pulling. Work or play.
My 2DR with my M416 trailer. Just on a quick test of the new trailer light wiring I had installed. Real work comes this Friday and Saturday when I'm going to do some service project work, so the trailer will haul supplies in and debris out.
Ford Bronco Broncos Pulling Trailers Pics - Add Yours F3C665E8-4FD3-4557-9DF0-143253AFA867
truvkngfan
Adam
1995 Eddie Bauer Bronco, 2017 Nissan Pathfinder
here a little trailer with a nice motorcycle inside...........pulled just great, weight was just under 2000lb
Thanks for posting this, my bronco arrived in town by rail yesterday and I was a little worried about being able to tow my 6x12 (only holds bicycles).
Hudman316
Detroit
We’re considering buying an Aliner Expedition A frame pop up camper to tow with our Bronco. It’s approximately 2,250 dry (3,500 GVWR) with 240 lb hitch weight. It’s 18 feet long (bumper to hitch), 7 feet wide and 5 feet high when closed. It falls inside the towing capability specs for the Bronco (2.7 - 4 Dr Wildtrak) and it fits in our garage. The low profile (5 feet high) will make it a little better in the wind and get better MPG than a full size travel trailer.
Ford Bronco Broncos Pulling Trailers Pics - Add Yours 4EF7C7A8-050B-4E1D-B6CC-A44FF4B14A1B
AKBronc49
Russ
Anchorage, Alaska
Only moved a few items for work so far. Still need to get the SXS behind it.
Ford Bronco Broncos Pulling Trailers Pics - Add Yours 20220211_121856
Ford Bronco Broncos Pulling Trailers Pics - Add Yours 20220316_151814
Moto26
Tucson AZ
Got any pics of the hitch you’re using? I’m trying to visualize the difference between a “hitch extension” and an “extra-long hitch”…
killaz05
Anthony
Rockledge, FL
Ford Bronco Broncos Pulling Trailers Pics - Add Yours IMG_3167
bytheway
Brice
Louisville, KY
got my chalet arrowhead out of storage yesterday. Surprisingly the Bronco tows it better than my V8 4Runner did even without having a brake controller setup yet.
the hitch was somewhat of a disaster trying to use what I had on hand. I thought taking the spare off would fix my problems but then I worried the camera would get damaged since it sticks out even further. Used a hitch extension to move it up the road but definitely suggest the longer ball mount like pictured above. One unexpected problem was my safety chains wouldn’t reach so another thing to keep in mind with setting up your trailer for the bronco.
overall towed like a dream even with some heavy tongue weight. Two LP tanks and two batteries up there. My only complaint is you can’t lock out overdrive so I had to use manual mode to keep the rpm’s where I wanted them on the highway. Around town it handled shifting ok in drive.
Ford Bronco Broncos Pulling Trailers Pics - Add Yours F2786824-72E2-4FC4-B959-CD6BFF6D6207
Ford Bronco Broncos Pulling Trailers Pics - Add Yours 26217575-75A7-4DBB-91C9-875E05CECE0F
