Bronco Towing Capacity
mjcutri
M
Lisbon, Portugal / Pittsburgh, PA
2023 Bronco HE
I think it has more to do with springs and shocks.
The Bronco has about the same size brakes as the Colorado. The Colorado is heavier and tows 7700lbs.
It's the rear axle and springs. That's why the raptor can tow 4,500 and the Ranger 7,500 with the same engines/transmissions/brakes.
The Raptor also has additional frame bracing for the hitch.
Arrowbear Rider
Marcus
Laguna Woods, Ca
Bronco, Triumph Thunderbird Commander 1700
It's a combination of frame, with brakes & suspension considered too, hell, even trans-cooling can be considered/upgraded in a truck's tow package (mostly HD trucks); the Raptor has frame and suspension upgrades for desert running that also increases it's towing capability.
From R&T:
" Where the real engineering lies in the Bronco Raptor, though, is in the chassis and suspension. Bronco Raptor's frame has been revamped with beefier shock towers, a B pillar crossbar, and C pillar reinforcement to handle all of the bumps, jumps, and abuse expected from Raptor drivers. Those upgrades also mean a 50-percent increase in torsional rigidity versus the standard Bronco."
jzweedyk
Moab, UT
2025 Lincoln Navigator
Can the 2.3 do it, yes, but you would be better served with the 2.7.
lakesinai
Charleston SC
Hi all, I am in the process of starting a mobile bar business and need to tow a 2600lb dry trailer (it is around 3400lbs wet/full). I am looking at 22 / 23 Broncos and want to ensure I get the right one. Can the Base and up models all tow 3500 in the full size Bronco? Any suggestions on the 22 vs the 23? Also, my biggest question: can I get away with a 4cyl over the v6 to save money? I am starting this business with loans and want to save where I can. I definitely want a 4 door for a longer wheelbase to have less tail wagging when I tow. I am hearing that the turbo 4 cylinder will potentially be sufficient? Thanks for any knowledge and experiences some of you may have had in towing with your Bronco! I can't wait to be a part of this club! Appreciate the time.
Just for the record, and to clarify what the tow ratings mean, here is the link to the Motortrend 2015 article describing the capacities that a vehicle must meet to qualify for the SAE J-2807 Tow Standard. The testing is rigorous, up a steep incline, and down again. History: before 2015, a Mfgr could (and did) set their own towing numbers. They were not equal across platforms. I was tow vehicle shopping in 2013-2014, the disparities and generous claims were amazing! The year the manufacturers voluntarily adopted compliance, many models stated tow capacity suddenly changed, down, as if by magic! Read:
https://www.motortrend.com/how-to/1502-sae-j2807-tow-tests-the-standard/
PA BRaptor
Kevin
Western PA
Ford F350
Not to derail the the thread but a question for the OP...... Does a mobile bar require a liquor license like a fixed establishment? Cool idea. Just curious.
The limit is there because of two reasons
First is the coil over suspension is very soft, and very sensitive to how the trailer weight is distributed. This is the biggest difference between the Bronco and Ranger in how they will tow. It’s very easy to overextend your rear suspension trying to load a single axis trailer.
The second is that the hitch is just a glorified bumper hitch, so you can’t have a lot of weight on the tongue.
Any Bronco has more than enough power / torque / brakes to haul well past the weight limit - it’s just those two things that will hold you back.
Michigander
SE Michigan
SuperDuty
Don't forget about frontal area of the trailer. A large frontal area requires significantly more power (and therefore cooling capacity) to pull down the road at higher speeds.
Unfortunately, the only frontal area specs I could find were a bit confusing (it lists 20 sq ft for w/o trailer pkg, and 30 sq ft for raptor w/trailer pkg, but doesn't specify non-raptor w/trailer pkg).
Given that the trailer pkg is basically a hitch, it's probably safe to assume the limit for all non raptor is 20 Sq ft.
Kathryn1128
Kathryn
Hartford, CT
A 79' Scout II
Hi there! It does - but different requirements in each state. I see you are in PA. In CT it's a Catering license. :)
huey
kevin
Ontario & Kentucky
I might be wrong but I think the max is due to the breaks and Frame? Not to do with your engine choice.
it is more of the suspension. The ranger frame is almost identical, has the same 2.3 and tow capacity starts at 5,500 lbs
