Bronco Team 2 door.
Aonarch
Jack Hoff
MT
Btw, how diy is it? Could I work on it in my driveway or do I need a lift and a 6 pack?
I did it in on the ground. You only need a jack to help shift the axle.
It was super easy.
CarmeloS
Carmelo
Central Jersey
It was super easy.
gotcha. If I cant get my friend to help, then jack the rear or?
Aonarch
Jack Hoff
MT
Yup jack the driver's side rear of the frame IIRC.
It just takes a little to realign the track bar.
You can also skip the jack and just use a ratchet strap.
Ford Motor Company
Official Ford Account
Dearborn
Bronco, Bronco Sport
Picked up the long awaited and eventually dismissed base, base. I had lost all interest in the Bronco and had every intention of flipping it. Drove it home and it was so much fun I'm keeping it. Installed some Badlands takeoffs today. Tint the windows and I'm good to go.
Woohoo! We're so happy to hear you love it David! :)
CarmeloS
Carmelo
Central Jersey
Looking good, Carmelo! Thanks for sharing with the community. Here's to many more adventures with your Bronco.
Thank you, now the real fun can begin!
Already planning trips, and with the mods dwindling down (Now just installs on misc parts, and a track bar relocation kit), after birthdays (End of June to middle of July), able to save for the road ahead.
JojoReady
North Country
Silverado
Need running boards and to air down the Kenda’s, but so glad she’s back!
Nice job Carmelo, you have a beautiful build. You might want to consider adding a rear anti sway bar too in addition to the relocation bracket. It will really help stabilize the rear end after a lift. Belltech, Hellwig and OEM are options to consider. If your 2021 is an early one you won’t have the factory chassis mounting brackets and Belltech will be your only option.
CarmeloS
Carmelo
Central Jersey
Snap, forgot about it, and I do have the holes, so I can place it.
Not frugal or cheap, just Fathers Day, Birthday, 2 weeks, then rinse and repeat (Dads birthday is literally a month from Fathers Day, and I got 2 other birthdays in July), so looking for a relatively and done option for RSB
