Bronco Team 2 door.
AJKitebrder40
Adam
Charleston, SC
'23 Bronco Badlands 2D SAS, Eruption Green (Sold), '25 Toyota Tacoma TRD Off Roa
Good timing, because I just joined the club, just waiting on consistently warm temps (it's 38 this AM), and I'll have a pretty close to matching photo.
Ford Bronco Bronco Team 2 door. Bronco1
Jakethesnake
Jake
Philadelphia pa
2007 GX470. 2002 Suburban. 2016 Subaru Impreza
Finally got my iconic silver 2 door base Mansquatch yesterday. Loving it so far. Only problem is they forgot my up fitter switches 😡. Other than that and not fitting in the garage with the roof rack I love it. Did a little mock of what it’s gonna look like with new wheels/tire combo and I think it’s gonna look sweet.
Ford Bronco Bronco Team 2 door. F38EDAAF-85B9-471F-98A1-A3AB93E3BF3E
Ford Bronco Bronco Team 2 door. 913C9175-5D35-4004-A9C4-8CD9522CE40A
Ford Bronco Bronco Team 2 door. 1671D342-FB9D-4A76-B6C0-73C1C04EFF2F
Toccoa
Isuzu Rodeo Sport
Did they forgot to add it to your order or did Ford forgot to add it to your Bronco (on window sticker but not installed)? Still looks good. Silver is a completely underrated color. BaseMansquatch FTW!
Jakethesnake
Jake
Philadelphia pa
Not sure I can find out. Will the dealer own up to it if they did ? I’m gonna have to go through my emails and see if I can trace back where the disconnect happened. Problem is that I ordered over a grand in lights and now it becomes a much bigger installation. Super frustrating.
BAUS67
redneck
Central PA
When Ford 99'ed the orders to make you re-order many have posted here that the switches and sometimes even the Squatch would be deleted from the order and needed to be put back on. Maybe it was missed during the re-order process.
Toccoa
Isuzu Rodeo Sport
To remove Ford “forgetting” to install it or just forgetting to install the switches, check you window sticker. It would be listed as an option (i.e. you paid for it). If you see it listed on the window sticker, check under the hood. If the wiring is there, then Ford just goofed on the switch panel. If those fail, start looking for the order sheet your dealer sent Ford. As @BAUS67 said, those options sometimes got lost in the reorder process.
Jakethesnake
Jake
Philadelphia pa
Hope that is the case. It’s not on the sticker so I won’t get my hopes up but I will look under the hood when I get done work and pray I’ll find a little surprise. Otherwise all the lights I bought become a bigger install than I’d hoped
Toccoa
Isuzu Rodeo Sport
If it's not on the window sticker it's probably not on the Bronco. However...
In this thread here, @Middleton Motorsports shows you how to resolve the problem on your own.
https://www.bronco6g.com/forum/threads/ford-oem-bronco-upfitter-switches-install-video.54057/
They even have a video to walk you through it.
mlugb6ro
Monte
2d Rubicon, escalade
Does anyone have a picture of the adjustment controls of the vinyl drivers seat on a 2 door? I'd like to know if it has lumbar support.
Johnny Rebel
LA
2021 2D Big Bend, 2022 Bronco Raptor
If you end up not having the upfitter wiring under the hood and need to buy/install the factory switches, it's worth looking at other options like the SwitchPros SP9100 instead. IMO, it's an easier install than retrofitting the factory upfitters and will make wiring your lights a simpler process. Plus, it comes with additional functionality that the factory switches don't have.
In my case, the Baja Designs LP6's on the bumper have a high and low mode; each mode is on a separate switch. If both are enabled at the same time the light can be damaged, but the SP9100 can be programmed to turn off the high or low mode switch when the other one is enabled. You can buy a separate $100 harness from Baja Designs that does the same thing, but it's expensive and install is not as tidy.
Also, SDHQ makes a bracket for the SwitchPros Power Module that mounts in the inner fender behind the fuse box and keeps everything nice and neat.
Ford Bronco Bronco Team 2 door. SP9100 bracket
Jakethesnake
Jake
Philadelphia pa
Thank you sir. All very helpful information. Appreciate your reply
