Bronco Team 2 door.
jzweedyk
Moab, UT
2025 Lincoln Navigator
Took it out to Peek-a-Boo canyon just north of Kanab, UT. If you are ever in this area, this is a must see. You take a DEEP sand trail about a mile in with the Bronco. Don't forget to air down. It takes you right to the mouth of the slot canyon. The canyon goes about 1/3 mile in before it dead ends.
Ford Bronco Bronco Team 2 door. Trail 5
Ford Bronco Bronco Team 2 door. Trail 2
Ford Bronco Bronco Team 2 door. Trail 3
Ford Bronco Bronco Team 2 door. Trail 4
Ford Bronco Bronco Team 2 door. TRail 1
Quicklime
Lane County
Bronco Sasquatch 2 Dr hardtop
Finally got to put something on the finish of my daughter’s BD. I’ve been using this stuff since 2021. It’s an incredible value at $15 a bottle. It does last a full year if you are busy using your Bronco…
Ford Bronco Bronco Team 2 door. IMG_R_0475
Ford Bronco Bronco Team 2 door. IMG_9232
Ford Bronco Bronco Team 2 door. IMG_9231
Ford Bronco Bronco Team 2 door. IMG_9229
Ford Motor Company
Official Ford Account
Dearborn
Bronco, Bronco Sport
Wow! Thanks for sharing these awesome photos with us, Jim!
Dialtone
Twilight Zone
Bronco Big Bend Mid
I tried that Turtle Wax Ceramic Spray Coating product, and it left my red car with lots of streaks. Mostly visible at an angle when the light reflected. I could not buff them out. Took a lot of time messing around with a damp cloth to cut through and get rid of the smearing. The cuss words were flying. Hard to tell how much product was left after all the work correcting the streaking.
I ended up instead buying some quality carnauba wax ... old school apply, wait until haze, and buff out. Worked great.
Do you have a trick to avoiding streaks with the TW Ceramic Spray?
Streaking issue mentioned here at the 3:56 mark:
Hot surface or too large a working area will streak up pretty quick on you. If wait for a flash and haze it's too lat hot too thick. Dark colors are a real challenge. I've worked the job on my black truck more than once. A wait and reapply can bail you out sometimes or a very fine swirl remover or clay bar. There's a reason a pro charge $$ I'm cheap so I accept screwing up until I get it right a part of the process.
Dialtone
Twilight Zone
Bronco Big Bend Mid
Good video. I use a battery powered leaf blower for the nooks and crannies to chase out water.
KRAKEN
Andy
North Alabama
2023 2 DOOR BRONCO, 2014 F150 XLT, 2006 F150 FX4
Where did you get those Badlands sill guards?... they look good.
