Bronco Speaker connections
Blksn955.o
Greg
Wentzville, MO
Looking to buy some open ended plugs to plug into the factory harness. I have seen two referenced but can we get a confirmation maybe?
Amazon says 98+ Ford
The below link is from another thread on here from the B&O on the Outer Banks.
Link in other thread
Both look like the same but does this look like it works on a 2021 Bronco?
Specifically the std 6 speaker setup.
peta8368
Norwalk, CA
2016 Polaris Slingshot
Here's some pictures of the 4" speakers' connector, from another thread.
https://www.bronco6g.com/forum/thre...tereo-wiring-diagram.20275/page-6#post-727393
The connector does not look the same as the commonly found "98-up Ford" connectors.
Our best guess is these connectors mentioned here, orderable from Mouser.com, available in October. But these are connectors only, you still need the pin receptacles and wires to go with them
https://www.bronco6g.com/forum/thre...tereo-wiring-diagram.20275/page-7#post-728218
Peter
flip
Phil
IN
www.ruxerparts.com
Fords
I can get you part numbers for the harness side which means you would have to find the mating one to work. I know one is an AMP/TE but have not had much luck figuring out what type/line.
Rear roll bar and dash speaker connection.
Ford Bronco Bronco Speaker connections 1627994142655
Ford Bronco Bronco Speaker connections 1627994312310
Kick panel.
Ford Bronco Bronco Speaker connections 1627994231976
Blksn955.o
Greg
Wentzville, MO
Thank you @flip
So we just need to find the corresponding male for these plugs as the ones you posted above look to be female that are the ends of the overall harness.
That also answers a question I thought of...are the dash and kick panel the same plug.
flip
Phil
IN
www.ruxerparts.com
Fords
Thank you @flip
Yes. The white one is a of TE/AMP Yazaki 7183-4347 that I actually had from an old harness. The imprint is sooooooo small I could only make out the triangle marking but not any numbers. Searched Yazaki's website for a long time and it appears they don't make the male side.
If you look at the diagram 4 go into the kick panel. Two of those then go back up to the dash speakers. I can understand saving a few feet of wiring but is the kick panel speaker connector just a jumper on the speaker side or is it some sort of component?
