GETSCHWIFTY
Rick Sanchez
Parts Unknown
2021 bronco
This is really neat! Looking forward to seeing some reviews
Mdemieville
mark
2011 Lincoln MKZ hybrid
I’m wondering the same thing. Will the mounting brackets for each of them work with the other?
It almost looks like you could slip this right over the JCR mount. If not it doesn't look like it would be hard to fab up something.
Diabolical Inc
Diabolical Inc
Lux Sponsor (Level 2)
shop.diabolicalinc.com
2020 Rubicon, 2021 Bronco Wildtrak
@Diabolical Inc any thoughts on if a hardtop with JCR offroad molle panels?
I don't see any reason why it wouldn't. Worse case is you would have to drill some hole in the slipstream to mount the bottom of the molle.
Mdemieville
mark
Thank you. That's what I was thinking. Just an L bracket at the bottom of the molle
Bonnie6G
Kyle
Denver
Badlands LuxSquatch
Hey Everyone! We are here to introduce the new Bronco Slipstream Security Enclosure. This isn't just a box, it's a full enclosure for your 4 door Bronco. We will be headed back to the Diabolical Garage to work on the 2 Door model as well.
So let me introduce you to the Owner, Alan and he will walk you thru some of its many features.
Hey Diabolical team, just checking in to see if you might have a rough timeline for when these will start to ship?
Diabolical Inc
Diabolical Inc
First production run is already in process for cutting and bending, we will have a better idea once they hit power coat. Which should be next week
Bearcat1
Travis
2017 Expedition Limited, 2006 BMW 330xi
I just installed the IAG soft top lift, works awesome. I am a little concerned with how this will work with the slipstream. The IAG gas struts will coincide fine from a mounting perspective, but it takes a lot of force to close the soft top back with the struts installed. You have to grab the backside of the top and pull down. I feel like where I grab under the bottom of the top to close it, my hands will get pinched by the slipstream backplate that tucks into the tailgate. I know the slipstream has cutouts to access the soft top lift levers, but I can't imagine there is much room there. Any thoughts on this? Here is the video for the IAG operation.
Around the 10 second mark it what has me concerned. I tested trying to close the top by pulling down on the outside, not easy to do!
jrstorm1007
Long Island, NY
2021 Bronco, 2007 Ford Edge
Ditto for everything in the post
Diabolical Inc
Diabolical Inc
we design our system to work with OEM equipment. If we catered to every aftermarket parts we would be constantly revising it. Not to mention the R&D costs.
mid we changed the function and design of the slipstream it would ruin everything that it is. The tailskin is part of the security features of the system. It can be removed, but you would lose the security of the entire system.
mcashin1
Winston-Salem, NC
Toyota 4Runner
I figured that was the case. Definitely want the security. Just hoping the IAG struts work with it (which I would consider to be a bonus). Guess we'll see!
