MillerBuilt
Tony
Washington
Chevy 3500, Dodge 2500, F150, Mercedez E350
Getting excited to receive!
Dubsilk
Wayne
Arkansas
2020 M240 6MT
Getting the shop ready to ship out the first sets soon!
Now backed up are you with orders? For example, will an order today be delivered before the summer?
Diabolical Inc
Diabolical Inc
Lux Sponsor (Level 2)
shop.diabolicalinc.com
2020 Rubicon, 2021 Bronco Wildtrak
Not quite backed up yet, our first run of 100 units are about close to being sold, but the next order will go in soon.
bomchet
Bom
northern va
2014 dodge durango
Will the SlipStream security enclosure be on your site for the discount that just came out to the 28th?
jalawson
TX
‘22 Bronco, ‘17 F150
Hey Everyone! We are here to introduce the new Bronco Slipstream Security Enclosure. This isn't just a box, it's a full enclosure for your 4 door Bronco. We will be headed back to the Diabolical Garage to work on the 2 Door model as well.
So let me introduce you to the Owner, Alan and he will walk you thru some of its many features.
Couple questions:
1) Is there any noise from the pins that allow quick disassembly vibrating under normal road driving and/or off-road driving?
2) How much of the enclosure needs to be removed in order to remove and replace the entire soft top?
Diabolical Inc
Diabolical Inc
Couple questions:
Pins: there is foam between the metal parts, what we have done is…if you notice any rattle from the pins, just add more peel and stick foam (which tightens up between the panels)
as far as the soft top, you only need to change out the skin brackets 4 bolts and the bracket to switch between between hard top and soft top.
jalawson
TX
For the soft top question I think you misunderstood. If I have the soft top on and the slipstream on and I want to remove the entire soft top from the vehicle do I need to remove the entire slipstream or can the soft top be removed with the slipstream in place?
Diabolical Inc
Diabolical Inc
Its the same process. You would want to remove the soft top brackets, remove the soft top and then install the hard top (or no top) brackets. Same 4 Bolts (+ soft top hardware).
That’s the beauty of our system.
Bad_Bronco
Peter
Port Coquitlam, BC
1963 Chevy Nova SS, 2021 Ford Bronco WildTrak
@Diabolical Inc Any idea as to when you will have the Slipstream for the 2 door ready to go??
I like your system better than the Ford one, so can't wait to swap it out....thanks....
timstrong20
Tim
Georgia
2010 Toyota Venza and 2020 Honda Civic Hatchback
I am sure I missed it, but what is the price for this? Like the concept very much.
timstrong20
Tim
Georgia
