Bronco Rear Speaker Pod Upgrade - SSV Works
Switchworks_Kyle
Kyle
Oxnard California
2022 Ford Bronco
The Ford Bronco comes with a small, cheap speaker in the rear attached to the factory roll-cage. The SSV Works Rear Speaker-Pod upgrade allows you to replace those factory speakers with a set of larger, more powerful 6.5" weatherproof speakers.
Plug-&-Pay: By replacing the factory speakers, we utilize the factory harnessing. You know what that means right? Of course, our Bronco Speaker-Pods are a full plug-&-play installation on both standard and B&O factory systems.
These speakers are injection molded out of ASA plastic for maximum strength and ability to withstand extreme hot and cold temperatures. Metal support plates are made of 2mm powder coated mild steel and add additional mounting points that help make installing the speaker converts a breeze.
DM us for a discount code to our site!
Configure:
6.5" 120w SSV Speaker
Unloaded (No Speakers)
Limited Lifetime Warranty (On both the SSV Works Speakers and Pods)
Currently not compatible with Bronco Raptor.
*Patent Pending
4-Door Bronco https://ssvworks.com/collections/bron...
2-Door Bronco https://ssvworks.com/collections/bron...
Be sure to check out our Alpha12 Digital Smart Switcher too!
Ixr
2022 2DR BASE SAS
I have the mabett pods for the 2 door and they hit the seatbelts, do the 2 door version of these clear the seatbelts?
Draughon
Daylon
Dallas
BMW 4-Series
Love mine - it was a no-brainer upgrade.
Jazer
Jessica
2.7 OBX
Did you do the forscan update to unlock rull range to the rear? The rear pods are the only audio upgrade I did not do, and I am not yet convinced it's worth it to swap them without delving into forscan.
Draughon
Daylon
Dallas
BMW 4-Series
I have the B&O and just did a straight swap, i.e. unplug the old pods, plug these in, and it sounds great.
No forscan necessary.
Switchworks_Kyle
Switchworks_Kyle
Kyle
Oxnard California
2022 Ford Bronco
Switchworks_Kyle
Switchworks_Kyle
Kyle
Oxnard California
2022 Ford Bronco
Hello,
The speakers will not impede with the seatbelts. Our engineering team designs them specifically for each vehicle and run them through multiple tests to ensure proper fitment.
Let me know if you have any other questions, Thank you!
Lak34ers
Troy
Seattle
Configure:
*Patent Pending
Do they fit with the Ford Performance c brace installed?
Switchworks_Kyle
Switchworks_Kyle
Kyle
Oxnard California
2022 Ford Bronco
Hey Troy,
Unfortunately they will not fit with the C Brace, sorry.
We made the pods before the Raptor models were released so we didn't have that info to build around the Braces.
