4x4TruckLEDs.com
Adam
Lindenhurst, NY
www.4x4TruckLEDs.com
We picked this up at the dealer yesterday for a friend of ours. Drove it straight to our shop and began working on it....
Ford Bronco Bronco Raptor With Proper Lights Setup Raptor2 (small)
Ford Bronco Bronco Raptor With Proper Lights Setup Raptor3 (small)
Ford Bronco Bronco Raptor With Proper Lights Setup Raptor4 (small)
Ford Bronco Bronco Raptor With Proper Lights Setup Raptor1 (small)
Ford Bronco Bronco Raptor With Proper Lights Setup Raptor6 (small)
Ford Bronco Bronco Raptor With Proper Lights Setup Raptor7 (small)
Ford Bronco Bronco Raptor With Proper Lights Setup Raptor9 (small)
Ford Bronco Bronco Raptor With Proper Lights Setup Raptor10 (small)
Ford Bronco Bronco Raptor With Proper Lights Setup Raptor15 (small)
ChipM
Chip
Warrenton Va
17 4 Door SD, 00 4 Door SD, 65 Fastback
Nice looking set up, which set up did you use inside the modular bumper?
4x4TruckLEDs.com
4x4TruckLEDs.com
Adam
Lindenhurst, NY
We were originally going to use our Flush Mount Kit (https://www.4x4truckleds.com/baja-d...ad-bezel-flush-brackets-for-2021-ford-bronco/) but the customer wanted 2 larger lights, so we did our open bracket (which would actually allow for 3x Squadrons, but we put the S2 on his factory fog light switch): https://www.4x4truckleds.com/baja-d...-w-kr-off-road-brackets-for-2021-ford-bronco/
We make pigtails so they plugged right into the factory fog light switch + the Aux1 switch. Leaving us just 1 harness to run for the 3rd set of lights.
Aztec1382
Sam
F350
The lp4 look perfect
Do you sell a mount for the jeep gladiator im the same spot
Losy
Long Beach, CA
Gen 1 Raptor, GL63, S7
Has Baja Designs resolved their paint issues on the LP’s? On my second set in 2 years for really bad faded paint. And it is not due to any products I use to wash the truck. Even thought BD will replace the lights, I am losing faith in their painted metal parts.
4x4TruckLEDs.com
4x4TruckLEDs.com
Adam
Lindenhurst, NY
4x4TruckLEDs.com
4x4TruckLEDs.com
Adam
Lindenhurst, NY
Yes. What happened was they had a bad batch of powder coating from their vendor. They are replacing the housings though under warranty if you contact them and setup an RMA.
Aztec1382
Sam
F350
Losy
Long Beach, CA
Good to know. Big fan of their lights. Once my Bronco arrives I will order a set from you guys.
JetG
Jet
TX & FL
2018 Macan Turbo w/PP & 2016 911 Turbo Vert
The pillar lights are awesome. I am guessing LP4 and what bracket? Guess it can be ordered like you have it. Can you shoot me a price of the kit?
4x4TruckLEDs.com
4x4TruckLEDs.com
Adam
Lindenhurst, NY
4x4TruckLEDs.com
4x4TruckLEDs.com
Adam
Lindenhurst, NY
