lsustang05
Houston
2013 Ford Raptor SuperCab
It will not be anywhere near 80k. Think about it has to be less than the raptor and the raptor is no where near 80k
The current Raptor is $73K loaded out. Dollars to donuts the new Raptor pushes $80K easy.
My guess on a Bronco Raptor price point would be $70k-ish loaded out. Same as what the limited F.E. is, maybe a bit more. Too much higher and you eat into Raptor sales.
guernsej
CA
2017 Raptor
I don't think Ford is all that worried about cannibalizing sales. They'll be selling Broncos as fast as they can build them for at least the next couple years.
If anything, they'll be happy to shift some of the MY21/22 demand to an even more profitable trim in MY23.
Badplaid72
Paul
San Diego, Ca
Various
I can't comment on your other questions, but wanted to ask what you meant by this:
If you are saying that the OB with SAS is a better deal than the Wildtrak, I would disagree. A 2-dr OB with 2.7 + SAS + Mod Hardtop is $800 more than the standard Wildtrak and matches it exactly equipment-wise. Not sure about 4-dr though.
Or if you are comparing the OB w/ SAS with a BL w/ SAS, then essentially you are paying $2k more for the BL to get all of the armor & steel bumpers.
Your right, my mistake, I was thinking something else. It’s hard to keep it all straight. My biggest point is there anything special about the Wildtrak? It seems like you can option all the trims to the same capability.
BroncoBoy22
Laker Land
'11 Mustang GT 5.0
HYPE!!!!
What if they surprise us and it’s a late 2021 model?! ?
I highly doubt it, but I’d freak it if so
Raptor911
Raptor911
Broadlands, VA
I guess we will have to see.
and BTW .. not sure if you know this or that it matters. The oversized front fenders and rear bedsides on the Raptor is not metal. It is a composite. The hood is also a composite. Has been this way since 2010.
I don't need to work for Ford to logically think about it. I also come from a design and product development background. Looking at Raptor again - you think the fender flares magically end on the front quarter panel-fender/in front of the front door just because? Or for design? No. They do that so they can use the same cab and doors as the normal F-150. They're not going to develop a new door skin just for one trim of a product. The back flare has more leeway as it can take up as much of the bed side as they want.
Now let's take that logic and look at Bronco. The front fender flare could be handled the same way as Raptor - the "flat" metal panel and the plastic one could be replaced with a bulging fender fender assembly that terminates just before the door - that I agree with. You MIGHT be able to barely get away with it on the 2 door rear quarter panel, but it'd have the same interaction with the door - terminating where the door ends, as again, they're not developing a new door for this.
Now lets look at the 4 door - here's where the real problems lie. As with the 2 door, it's possible that they could do a Raptor-style bulging FRONT fender that terminates before the door.
But then you go to the rear door, which cuts into the wheel well opening. Taking the Raptor approach would be impossible without designing a completely new door skin, as you're not going to have a bulging fender 3/4 of the way and then just stop at the door, with an awkward flat piece/flare where the door goes. The only alternative to this problem would be attaching a plastic piece to the door to continue the bulging flare of the quarter panel, and that just wouldn't look right unless the flares too were just of the "added on" variety.
I hope I'm getting my point across better with images, otherwise I'll have to mock something up in photoshop.
broncobuster2550
Dearborn
2023 Ford Bronco
maybe im alone here, but I don’t think those are the intended tires (wheels)..? Personally, I think the stance is odd looking. all the “oh’s” and “ah’s” are killing me... too much space there, and no doubt it will be filled with way more rubber. My three cents
Correct.
NVCowboy
William
Henderson, NV
4 Door Production Body w/ Bronco-R suspension? All the Suspension tastings been done, just have to marry it to street legal body. It’s what I would do if I were Ford, but Bullit Green would have been an available color if I were Ford.
NOVA
'16 4runner- 33s, Dirtking UCA&LCAs, 6112s, etc
i think im going to bail on my reservation and wait for the warthog/whatever it will be called. that green would be fantastic
rmc523
South Florida
2022 Bronco Wildtrak
I know. My dad has one. Doesn't change the fact that they're not redoing the doors for a low production model like that.
Raptor911
Raptor911
Broadlands, VA
again. We will see. Btw the raptor was never meant to be a large vol vehicle but sales has grown every year since 2010.
mike.s
Wrangler
Really hope they aren't just gonna slap wider plastic flares on to accommodate the wider track. Everything else looks awesome, and the tech is what I was expecting
guernsej
CA
2017 Raptor
We're not getting the Bronco R suspension. No way it's coming with dual shocks up front, pneumatic bumps and 4.0 FRS shocks with 18" of travel in the rear FROM THE FACTORY! I'd shit my pants.
For comparison, upgrading a Raptor to run that kind of kit costs $20-30k (would need SVC Mid Travel or RPG BOLT kit plus shocks in front, RPG RST18 plus shocks and bumps in rear).
BroncOcotillo
Mach1
My wild guess is that it is a joint effort with Roush which just happens to be near the approximated location of the photos.
Roush or Shelby performance packages for the new Bronco would be nice to see.
calgecko
Sacramento, CA
www.instagram.com
2021 Chevy ZR2 Bison V6
