Bronco Raptor Ford Tune
roidragejd
gloucester Ma
2022 ford bronco raptor
Looking for some help. When the Ford performance tuner was first installed i used to see 20-22 PSI on the boost. Now lately i can see higher than 18. I have had it reinstalled and same result. Only thing i haven't tried is to put back to stock THEN retune.
Also, when i plug my tuner into the computer to check for updates ETC it never connects.
5POINT56
2024 Bronco Raptor
Interested in this as well. Never got above 22 boost, sometimes less. It’s hard to determine if it’s even working, since the dealership did the install on their PC.
Bigmoose
Jon
RI
2019 Flex Ecoboost Limited
probably due to the colder temps and cooler air charge. Less pressure need to meet load demand with the cooler air charge.
5POINT56
2024 Bronco Raptor
Living in FL, colder air temps aren’t at play. What sort of boost would be considered normal for the ProCal and is there any way to check to see if it’s still active if a system update (or some other factor) disengaged it?
