Bronco owner with F150 question
ksdon
kansas
I know there is a F150 forum somewhere in the internet, but I also find mostly good advice here.
Since I am a Bronco owner, maybe I can ask a question about a F150???
2025 F150 with 3.5 Ecoboost....not the hybrid version. If I remove the active air dam in order to install a front skid plate, is there anything to be aware of that may be an issue? What is the likelihood of this causing a warranty issue.
orion
Jeremy
17' F-250, 17' Explorer
I got a 2017 F-250 and use the www.ford-trucks.com forum. Pretty good place...
Don't know about your question but they should know over there. I know on the Bronco it's not a big deal but may be on the F-150.
ksdon
ksdon
kansas
I'll check there. Thanks
DALOLA
Retired
Ohio 🇺🇸
'24 Mach-E, '22 Maverick, Hot Rods
I think this is probably the "volume" F150 forum on the web, I was active when I had my 2018.
https://www.f150forum.com/
(as to your question, should be no concerns... the front air dam is for FE improvement at higher speeds. )
ksdon
ksdon
kansas
Watched a video and at 47-48 mph it dropped down approximately 4 to 5 inches. One video stated that Ford claims a 4% improvement.......but does not state what that improvement is. I suppose a wind tunnel might show the drag affects of wind getting under the truck.
Even without the "active air dam" portion dropping lower, ours has enough length to whack the ruts and dirt clods on our road after a rain. Thinking it might be less expensive to remove it.
orion
Jeremy
Ah, I was thinking the grill shutters for some reason, 😅.
Administrator
Administrator
Staff member
Doug
Bronco6g.com
F150gen14.com is the sister site.
You can copy your account over easily using you Account Copy menu - https://www.bronco6g.com/forum/account/copy
ksdon
ksdon
kansas
Thank you, I did not know this.......see, by post here I am now smarter!!!!!
I appreciate the info y'all have provided.
