California Bronco OBX Tire Help
obx007
Norcal, CA
2025 Ford Bronco OBX
Hey guys! I just picked up a 2025 Bronco OBX (non-sas) and I was hoping to get some new tires(maybe wheels) on it. I don’t really want to lift it or do any suspension mods as it’ll typically be used on-road. I found some Badland takeoffs with 1500 miles on them for $500 and I was wondering if you all think it would be worth purchasing. The take offs are the Goodyear Territory MT, 285/70/17s(see attached). Any thoughts or suggestions?
Ford Bronco Bronco OBX Tire Help IMG_7419
Ford Bronco Bronco OBX Tire Help IMG_7429
aka217
Andrew
Oakland, CA
2007 IS250
$500 is pretty stellar, I see these around $1000 typically. these should be no issue for your trim as well, i guess the only thing to consider if it includes tmps or if you'll have to transfer yours over.
FoCoBronc
Colorado Springs
‘26 BL - previous ‘22 OBX, Tacoma, X3, MDX, Bronco II
Will work fine, and good price too. I was in same situation with OBX and not wanting to lift. I put on the optional Badlands wheels and tires, along with front and rear bumper
Ford Bronco Bronco OBX Tire Help IMG_8755_Original
obx007
Norcal, CA
Did you have to take the crash bars off? Looks sick
FoCoBronc
Colorado Springs
Nope- no modifications. From everything I've read you can go up to 34" tires without lift or crash bar removal, but the offset and tire width might make a difference too. I've seen a few posts on 35s without lift too. That IDK.....I'm planning to put 34s on my 26 non-sas Badlands when OEM tires go
Montana Bronco
Montana
Chevy
OP, that is a good deal for $500. Buy them.
Your rig will look dope.
