PowPow
PA
2018 Tahoe
I respect your opinion. I do love the outdoors, and I strongly adhere to leave no trace principles. While not an excuse to purposely destroy the land, it should be understood that Johnson Valley OHV Area is not exactly an untouched pristine wilderness. It's an open vehicle area containing dozens of mines and prospects, and criss-crossed with thousands of roads, trails, and tracks.
While I generally agree with your perspective in most cases, and I'd hate to see mounds of rocks or other markers dotting the landscape every hundred yards, there are some important locations and routes that deserve a memorial or waymarker. Already there are man-made survey monuments (usually either chiseled stone or capped metal pipe, often with rock mounds next to them) every half-mile on a 1 mile by 1 mile grid covering the vast majority of the Western US that define land ownership of private lands and the management agency boundaries of public lands, including throughout Johnson Valley. The only exceptions I know of are Spanish Land Grants that pre-existed the Public Lands Survey System, some wilderness areas, and some tribal lands (and some as-yet unsurveyed land in Alaska). Many of the monuments date back to the late 1800s. If you look around, you may see some of them there. The USGS Topo Maps show those 1 mile by 1 mile squares (known as sections), usually as red lines, and the sidelines of each one of those squares is (or at one time was) marked on the ground at the corners and midpoints (hint: if you see a '+' mark on the map, the monument was recovered by USGS surveyors in the course of their cadastral work). Where public and or private ownership boundaries follow divisions of those sections into 1/4 sections, or 1/16 sections (what your grandfather might have called the "back forty"), or even smaller divisions, there is usually a marker. There is probably a survey monument at the corners of the land your home sits on. Other monuments not on the grid lines have been installed at various locations for other uses as well, such as mining claims, benchmarks, triangulation stations (those are shown on the USGS maps as triangles), reference monuments, witness monuments, bearing trees (those are really cool to find) and a host of others. In fact there is a triangulation station about a mile and a half Northwest of Bronco Knoll that I intend to search for next time I'm out there.
If the Bureau of Land Management objects to this cairn, then I will remove it. Otherwise, I believe this spot is of significant importance to the off-roading community and merits a respectful monument. I believe this cairn to be an appropriate way to preserve Bronco history and create a challenging and rewarding destination for off-road enthusiasts.
(Also, I just happen to earn a living by marking my and your territory.)
As a side note, Johnson Valley is negatively impacted by litter. I hauled away a garbage bag full of trash that I picked up around my campsite, and I challenge every other member of this forum to do the same whenever they get a chance to enjoy our public lands.
I appreciate the reply. I don't know the area, so will trust what you say it is. In the end, you're free to do whatever you want. I'm just hoping that maybe I, at the very least, brought some attention to the leave no trace. And maybe some people will read this and think twice the next time they're out in the wild about leaving their mark.
Torgsurv
Torgsurv
Blake
Vista, CA
1991 Bronco XLT 5.0 "Mando"
State Plane scaled to ground please, US FT, :) JK
There's a fellow surveyor. I know you were kidding, but I can't resist:
SPC Zone CA 5 (0405)
Meters:
N: 614,537.653​
E: 2,114,124.206​
US Survey Feet:
N: 2,016,195.616​
E: 6,936,089.166​
International Feet:
N: 2,016,199.648​
E: 6,936,103.038​
I need a second point before I can scale a measurement between them to ground distance.
I'll refrain from adding the convergence angle, combined scale factor, and velocity. :LOL:
ronstar
Ron
Illinois
F-150, Jeep JL
As a fellow surveyor (now retired), I appreciate the work you put in on this! I was a surveyor for 40 years and the Bronco will be my first vehicle with latitude and longitude stamped on it.
srick76
NJ
F150, 69 Bronco, Durango RT
This is a featured trail write-up that I hope will be of interest to all Bronco enthusiasts, especially those who own/will own a 6G.
I recently saw a photo taken by a fellow Bronco enthusiast who goes by Utah.Bronco on Instagram, which showed latitude and longitude coordinates (easter egg) hidden on the new 2021 Ford Bronco.
I was extremely curious about where the coordinates were pointing, and was delighted to discover that the secret location was in Johnson Valley OHV Area, just a few hours from where I live. I had never been to JV before, but always wanted to go, so I began researching the area and planning a trip. I couldn't think of a more fitting day to visit the spot than New Years Day 2021, to celebrate the first day of the year of the new Bronco!
The coordinates are on the top of a small hill in the Northwestern part of the OHV area, about 5 miles East by Northeast of Cougar Buttes, just West of Anderson Dry Lake, and about 500 feet above the surrounding valley. I used Google Earth to scout out the three routes that I considered to be the most likely to allow me to get up the hill in my completely stock 1991 Bronco XLT.
I first attempted the Southern route, but the steep 35%+ hill climb with loose rocks and gravel proved to be too steep. (I may try it again next time with lower pressure in the tires.) Since I couldn't make it that way, I drove to around to the South end of Anderson Dry Lake and ascended the hill on the slightly less steep route up the East side of the hill. Here I encountered a couple of rocky ledges and took a little minor damage to a tube step, but was able to make it.
At the top, the trail turns to the West and follows the ridge to a somewhat prominent peak, with a relatively wide flat spot. At this point, I turned on the GPS (Locus app on my phone) and walked the last few feet to the precise location.
I half expected to find a plaque or memorial left there by the Ford Bronco testing team (T-shirts on the Ford Bronco amazon store tout Johnson Valley as "The Original Proving Ground", and many of the reveal photos and videos were shot there). Instead, I found nothing but rocks and great views. Being a land surveyor by profession, and having a penchant for monuments marking unique and special locations, I naturally raised a small cairn to mark the spot and named it Bronco Knoll.
On the descent, I attempted the third route, but was soon blocked by a very narrow rocky pass on a sidehill trail that I didn't dare attempt without supporting vehicles, and was forced to go back the way I had come. Maybe another day.
I'll be back in Johnson Valley again later this month and/or early next month for King of the Hammers, and will gladly lead a group of other adventurous souls to the site. I hope many Bronco owners will visit Bronco Knoll in the future and add a stone to the pile!
(Send me a PM if you'd like to have a kml file of the routes.)
[Edited for typos]
Awesome man, thank you for the narrative. I’m on the east coast but am seriously taking a vacation out there just for this and the wheel some the areas I’ve only seen on YouTube.
cybersal
Lee
Maryland
2002 Escape
Thanks @Torgsurv for the great story. It's a lifelong memory for you and your son, and those who make it to Bronco Brae.
BadlandsBroncoBen
Ben
Denver CO
2019 Subaru Outback, 2015 Subaru BRZ
[Edited for typos]
Awesome! thank you for sharing!
srick76
NJ
Those battle scars are kickass and a nice souvenir from your visit. This is precisely how automobiles become a part of us, like a friend or family member. They’re often with us on our most memorable adventures, sharing experiences with us, and sometimes the sole reason we’re able to have any kind of unique experience at all (in the case of more specialized vehicles). I find that I develop a much deeper connection to a car after a long road trip, especially if it didn’t leave me stranded or otherwise cause some huge inconvenience.
This may be my favorite post on 6g since joining. Well done, sir!
agreed 100% this post made my F'ing day!
Torgsurv
Torgsurv
Blake
Vista, CA
I made two more trips up Bronco Knoll last week, once with a buddy and his JK, and once with a couple other Broncos. More details later, but with the tires aired down I was able to make it up the steep slope on the South side of the Knoll this time.
Ford Bronco Bronco Knoll Named and Marked From Easter Egg Coordinates 20210204_103804
Ford Bronco Bronco Knoll Named and Marked From Easter Egg Coordinates 20210205_095436
Squatch
Was the rock from the Raptor video there?
Torgsurv
Torgsurv
Blake
Vista, CA
No, I don't think that was filmed on Bronco Knoll. It looked like a much more sandy terrain. Bronco Knoll has a lot more volcanic rock.
When I went up Thursday morning it looked unchanged from last month, but on Friday morning someone had added a couple rocks, so someone else was there between my two trips.
Squatch
Damn. I was thinking they actually added a rock to it. Hopefully, it was at least an homage to your work. The Warthog release video should definitely visit Bronco Knoll.
drive21bronco
North East USA
2021 Bronco Black Diamond
Soooo where at these "more details later??" ha, What's with the 6Gen bronco with you??
