Bronco fuel theft.
Patrickgault
Patrick Gault
South Carolina, USA
Ford Bronco, 2022 Outer Banks.
Has anyone heard of fuel being stolen from the Bronco? The fuel door doesn't lock and there is no cap. I've had no issues for 2 + years but I wonder. Does the design prevent syphering?
TXBronco1313
It’s not easy to push down a hose in there. You have to have the funnel that’s included in your Bronco to push gas down and same thing with pushing it out so yes the design makes it harder to siphon gas out of the Bronco but of course it’s not impossible​
flip
Phil
IN
www.ruxerparts.com
Fords
Impossible, no. Easily done, no. You would need the emergency filler funnel or something about the same diameter to push the internal ears back to allow the flapper to open. From there a small diameter hose would need to be passed down to the tank assuming there isn't some secondary obstruction I'm not aware of.
Occasionally people run into an issue at fuel stations where they can't insert the filler nozzle into the inlet because the nozzle is bent from being dropped or run over. Has to be very concentric to engage both ears at the same time or no joy. The capless system has been fairly reliable compared to previous versions and rarely fail from normal use.
2door
AA
!!!FOR SALE!!! 2022 Bronco® The Sasquatch™ 2-door
No need to worry about the absence of the locking fuel door. These days, thieves simply drill holes in gas tanks.
Ford Bronco Bronco fuel theft. 1721936485615-l
Patrickgault
Patrickgault
Patrick Gault
South Carolina, USA
Yikes. Yep, I guess it's a non-issue. Thanks for all of the feedback. Rock on!
Desert_Brush
SoCal
2015 Mini Cooper
I was going to say this too. They don't have to spend time syphoning when they can use a cheap drill and drain your tank from underneath.
Aonarch
Jack Hoff
MT
This.
If you are worried about this, make sure you have the steel fuel tank skid plate.
thesocalexplorer
Southern California
SeptuagenerianSasquatch
Randy
Massachusetts
While we're on the subject, avoid this (so called) "No Spill" fuel dispenser. The spout does not reach deeply enough into the Bronco fuel aperture, resulting in lots of gas spilling out, creating a big mess. Alsok you have to depress the green button (on the right, in this image), which has a pretty powerful spring, to open the valve. Depressing that button is quite a distraction while you're trying to manipulate the can's position to get flow.
Also, the ratchet lock on the can's neck is a real pain. I snapped it off so I could unscrew the dispenser cap. Eventually, I finally got my fuel out (some in the tank, the rest on the pavement) and returned the smelly mess to Home Depot.
It seems that this dispensing system is the only one sold legally in my high-regulation state. All for "safety" and "global warming," or something. Well, regulators gotta regulate--it's what they do, right?
Ford Bronco Bronco fuel theft. 1721948601470-9m
we're o
