Bronco build week 9/18/2023
swamp2
swamp2
Spoke it into existence!! Just checked and modules galore! Starting to feel real for the first time!
Our dates are almost identical. The modules indeed finally bring something concrete to the whole process. Congrats!
dumpsterfire22
Ryan
2015 F150 Platinum SuperCrew
Thanks! I've been using you and this thread as a gauge as to when I should expect updates. So far everything is falling in line. I guess now I'll be waiting to see when you post that yours is built and incessantly check my tracker for the days following!
swamp2
swamp2
I'm disappointed with the frequency of updates to the modules site and the main web tracker @dumpsterfire22 . I've heard that the normal yknd on the line is only about 2 days and I show zero changes since last Thu. I think I heard that one of ghdsd systems foex update kn Thursdays. I strongly suspect I've been built now for a bit as I'm sure MAP is running 7 days a week.
Spar10Bronco
Illinois
Bronco, Mustang
Glad to see many of us are in this together and getting updates that are aligned! Kinda surprising to me that others with the same original blend date to me aren’t even the same package (I’m a badlands non-sas and seeing others who are raptors or Sas packages) so make me really curious how the whole process works!
Anybody from the original 9/19 blend date (or that week) have an update yet showing the truck as built? Thanks!
dumpsterfire22
Ryan
Well, woke up this morning and my "in production" date has changed from 9/14 to 11/13. I'm guessing this is just an indication that they are getting everything caught up and back on track. Would love to get that built email by the end of the week!
dumpsterfire22
Ryan
While I was doing one of my many daily checks to all of the links possible, I noticed that there is now a tear tag code. I may be mistaken, but from what I've seen, this means that the build is complete. If anyone has any more knowledge on the tear tag let me know. Gonna be a anxiety filled next month or two!
kkslider2046
Canada
23' Bronco OBX SAS 2dr/ 25' Bronco OBX SAS 4dr ordered
What is a tear tag code? And where did you see it? 😮
swamp2
swamp2
Ha, I found a similar reference but IIRC it isn't a guaranteed that if TT then build complete. I've got a TT too but still only BCE modules (no PCM) and no updates on the tracker since modules popped last Thu.
I think we are down to weeks instead of months unless we have bad luck and get sent to a QA/touch up/missing parts/etc. type of hold (purgatory...).
swamp2
swamp2
dumpsterfire22
Ryan
Same here, no PCM. I did see in other posts that the tracker is probably the least accurate as for as progress. One guy mentioned showing still in production and his dealer called to let him know it had shipped. 🥴
swamp2
swamp2
I just called Ford. Apparently, I finished production on 11/1. The trackers, including web and module info are just not being updated, for me and likely for others, with anything close to resl time. I can expect delivery to my dealer between 10th (long past) and 16th. Unfortunately, they are not open now.
Call Ford.
dumpsterfire22
Ryan
Call Ford.
That’s awesome. Congrats! Well we’ve already established that our dates are almost identical. Plus it looks like you’re in CA which isn’t too far from AZ, so I’m hoping the news is the same for me. I’ll have to call tomorrow morning. Thanks for the heads up.
swamp2
swamp2
Thanks. I'm in San Diego, but my dealer is in Detroit. Best combination I could find of low ADM and high probability for allocation.
Williamoscar23
William
Ford Mustang GT
Call Ford.
This is great news - congrats you will have your raptor in no time!! I was worried cause no modules are popping up for me still so glad to know those trackers are not updating as they should! Can you post the ford information in this chat or tag the post with the info I plan to give ford a call tomorrow to get an update.
