Bronco Build Week 8/28/2023
Oly_Bronco
Oly_Bronco
WA
geargeek
Houston, TX
23 Bronco HE, (also owned and sold a 21 Bronco Sport BL)
Mine has been in built status, and yesterday I received an email with an updated ETA of 10/13-10/19.
And just now my order tracker changed from “built” to “order confirmed”, which seems to be what it initially does when shipped, so fingers still crossed.
I checked with Ford Marketing, and they said my vehicle has shipped.
Order status still shows “order confirmed”.
geargeek
Houston, TX
Yup - Modules populated and tear tag assigned back on 8/30 but now the window sticker isn’t available online.
FYI My window sticker became unavailable after my Bronco switched to “built” status. Mine was just confirmed to have shipped, and window sticker is still unavailable.
Bschurr
NY
When you say window sticker is gone does that mean the link or when you select the link nothing comes up? You can try manually bringing it up by adding your VIN to the end of the following address.
https://www.windowsticker.forddirect.com/windowsticker.pdf?vin=
Thanks - I have a screen shot and PDF download of the window sticker from late August.
For the last 2 weeks, when I select the link the page indicates “Please Check Back Later”. The window sticker was available after it was built for about 2 weeks and then the “Check back” messages appeared.
Bschurr
NY
Congrats on the shipping. I had a “Chat”online and they were useless aside from telling me to check the tracker and everything looks ok on their end and it’s anticipated arrival was 9/25 (which didn’t happen and they have no tracking details either)
Oly_Bronco
Oly_Bronco
WA
I had that happen before and it appeared the link was not correct but it would come up if you used the web address and added your VIN.
geargeek
Houston, TX
Thanks. When I manually created the link it worked for me. it appears to just be a problem with the link on the order status page.
julia
Julia
FL
Jeep Grand Cherokee
I wish we could see the path that it takes to get to us. I’m down in FL and my Bronco had made it to the rail yard in Orlando, FL but then checked today and it’s up in Talladega, AL.
Oly_Bronco
Oly_Bronco
WA
Does it indicate that the railcar is empty? If so it would mean that it's at the final rail yard waiting to be picked up by truck and taken to the dealer. You could try Ford chat to see if they can confirm.
julia
Julia
FL
Jeep Grand Cherokee
Yeah, that could make sense. I asked Ford chat if there was a way to track it once it’s been loaded onto a car carrier and they said I should still be able to use CSX…
Oly_Bronco
Oly_Bronco
WA
What I found is that once it was unloaded I was not able to track it because it will just continue to track the railcar which is now empty. My dealer gave me an estimate on how long it normally takes for them to receive once at the rail yard.
julia
Julia
FL
Jeep Grand Cherokee
That’s helpful! Thanks. My dealer is not the most enthusiastic. Very much so “I’ll tell you what you need to know” type attitude. It is what it is I guess 🤷🏼‍♀️
Bschurr
NY
Woo hoo - I received an email on 10/1 from Ford advising that my Raptor has been built.
Very curious timing since it’s been stuck “In Production” status since 8/30 (with modules populated & rear tag assigned) and the MAP plant has been on strike since 9/15.
I am not complaining but how does an idled manufacturing faculty magically complete my vehicle that was built 1 month earlier?
Taltyman
Paul
Forney tx
Jeep wrangler Rubicon, Ford F350, Braptor
When you look at their link it has CSX as part of the link address. I wonder if it will work if it ever gets on a rail car.
So from this page
https://shop.ford.com/vehicleordertracking/status/?vin=xxxxxxxx
The view window sticker link
https://www.cxservices.ford.com/inventory/WindowStickerV2?vin=xxxxxxxxxxxxxx&hash=xxxxx
doesn't work
But
https://www.windowsticker.forddirect.com/windowsticker.pdf?vin=xxxxxxxxxxxxxxxx works as stated in a previous post.
