Bronco Build Week 8/14/2023
Gregorian haydelis
Greg
Louisiana
But did anyone get an email saying it's been scheduled today?
TCB-1
TCB-1
Doug
Kansas
'23 Black Diamond, '06 Scion xB, '61 Impala
Checked this morning and I'm built too! PCM modules not up, but BCM's are. No tear tag info yet. Getting closer...
BigFootie
Wisconsin
You won’t see PCM modules.
SkiSquatch
Neil
BostonArea
2023 Bronco
Mine is showing‘Built’ as well this morning!!
rizion
Caleb
Houston
'22 JL 2dr, '21 Q5
On your window sticker, you will have a number like (example mine is 320230817). This is your blend date. So my blend was today, 8/17/23. Check that. That is the date the body and chassis is supposed to meet for the first time. I believe it will take a few days after that to change to "built". You'll also be able to tell when your rig is final because your modules will appear and a tear tag will be produced. There are a few really good posts on what to expect, how to find info, etc. Go to the top of the page in "TRACKERS" and there will be a ton of info there. But you are in production, which is a good thing!
cool. 8/23 blend date for me. thanks for the info.
SkiSquatch
Neil
BostonArea
2023 Bronco
At least for those scheduled last week and this week, modules popped at some point in the blend date (for the most part) .
brish
Arkansas
2015 Ford F-150
I have 8/16 blend date. BCE showed early on 8/17. Tear tag populated late on 8/17. Still showing "In Production." I'm 247/665.
TCB-1
TCB-1
Doug
Kansas
You are probably built. Sometimes it doesn't show up as built if you had options that needed to be installed off the main assembly line. I've seen a few builds that happened to. Keep watching though, you should show built soon if you have your BCM module and tear tag.
brish
Arkansas
2015 Ford F-150
Yeah. I agree. It is also showing up with an image in my Ford app now with the option to Activate Vehicle. Obviously, it does not let me do it yet, but certainly a sign that it is built. Ready for it to move to Shipped for sure. Thanks.
TCB-1
TCB-1
Doug
Kansas
Yep, I’m able to communicate with mine too on Fordpass. But like you said, can only do so much until we are able to get the codes of the screen at delivery.
But we’re ALIVE 👍👍
TCB-1
TCB-1
Doug
Kansas
Welp, went back to “Order Confirmed” which I think means it’s heading to a auto rack.
Ford Bronco Bronco Build Week 8/14/2023 336B22D1-124D-4A4F-A812-DD5B47EEE7FA
SkiSquatch
Neil
BostonArea
2023 Bronco
I have activate vehicle as well!!
I think that it may mean shipping.. look at other build week threads. May change soon
TCB-1
TCB-1
Doug
Kansas
Yeah, I remember reading what that meant when it goes back to “Order Confirmed” but forgot. Thanks for reminding me 👍
