Bronco bolts
DasQball
DasQball
Ryan
MI
Explorer ST, Bronco Wildtrak
Have you thought about buying lottery tickets? If so, what numbers would you play? Asking for a friend. ;)
Nope... Wouldn't even know how many numbers you need.
Toccoa
Isuzu Rodeo Sport
I actually don’t either. 😂 However, I do know that you’ve got a hot streak going with Bronco goodies.
Erock
US
2018 F150 Alpine edition
How much for one of the bolts? So I can be a step closer as well... lol
Razorbak86
Northwest Arkansas
Ford Bronco, BMW R1150 GS
My non-existent hardtop uses latches, it's easier than bolts.
Nice try there. It’s a reverse-mullet design. Party up front (easy-turn latches), and business in the back (T50 Torx bolts).
VoltageDrop
Fidalgo Island, WA
23, 69 Bronco
I bet @flip could get us specs on these...
Efthreeoh
Hummer H3T
Painful on the lack of fasteners knowledge on this thread :ROFLMAO: But worst is, anyone else notice the first millimeter or two of the threads are stripped...
North7
North Texas
SUV
Yes, but that is not stripped, it is designed that way to act as a guide pin for alignment through the two pieces of metal it holds together.
Efthreeoh
Hummer H3T
Not that I've seen every fastener type made :geek: , I've never seen a thread starter section that looks like that. Granted, the two bolt threads do look "stripped" in the same manner. Interesting way they form it.
flip
Phil
IN
www.ruxerparts.com
Fords
I try to order some tomorrow. Most of the parts we have looked up are in the national depot. We are serviced out of the Indy pdc but get a lot of stuff out of national or Memphis.
A good majority of hardware/fasteners are necked down on the leading edge. I think this is done to lessen the chances of cross threadding both on the production line and at the repair level. A lot of fasteners are installed with power tools on the line where as we generally start them by hand prior to using air, electric or mechanical tools.
Razorbak86
Northwest Arkansas
Correct. The bigger fastener is a SEMS screw (screw and washer assembly) with a dog point (or pilot point), which helps speed alignment during automated assembly.
For comparison, below is a replacement hard top retainer bolt sold by Quadratec for several Jeep Wrangler TJ and JK model years.
Ford Bronco Bronco bolts 28CA05C9-1C8E-45B5-9418-09427036F61C
https://www.quadratec.com/p/omix-ada/hardtop-bolt-m8x125-97-17-jeep-wrangler-tj-jk
This is a SEMS M8 x 1.25 x 25mm dog point T40 Torx.
Efthreeoh
Hummer H3T
That bolt seems to have a more smooth "dog point" vs. the Bronco bolt, which looks stripped to me. :LOL:
Erock
US
Thread rollers for the Bronco Bolts are newer... gotta wait for em to wear down a bit 🙂
