Bronco Attic?
myrealname123
Trent
Monterey, CA
'25 Bronco Badlands
Looks like it hangs down a bit when stuff is put in it which is fine. I have the hard top too; can you cinch it up flat against the roof when it's not being used to hold things? I don't want any rear seat passengers getting distracted by empty netting that's hanging down. Do you have a pic of it empty?
Yeah, you can definitely cinch it up even when it has stuff in it. I was moving some stuff out that day and hadn't adjusted it. I'll grab a Pic of it empty after work today. 👍
myrealname123
Trent
Monterey, CA
'25 Bronco Badlands
Here ya go. There's only a couple of inches above the attic to the roof panel when cinched up like this. Plenty of head room.
Ford Bronco Bronco Attic? 20220721_173428
Ford Bronco Bronco Attic? 20220721_173426
Ford Bronco Bronco Attic? 20220721_173417
newclubfront
Home
Car
It looks like you mounted yours in different holes than OP. Am I seeing that correctly? So rather than using those side facing holes that you have your grab handles in, you used holes on the top of the roll cage? Thanks for the pics!
myrealname123
Trent
Monterey, CA
'25 Bronco Badlands
You are right, I zip tied to the brackets that are on the roll cage and ended up liking it so I just left it. I got the attic back in January long before I had the grab handles and at the time I had not seen how long and secure those screws actually are and just did not mess with them. I will probably get around to trying it out like the OP did at some point. Definitely maybe :) Happy to share.
FFF
we have one of the Amazon Bronco hammocks over the rear seat for storage, easy to reach and perfect for throwing coats and such up onto.
Which one is this? I also have a 2 door bronco and like this positioning.
NCWildtrack
Clay
Sanford
2022 Wildtrack
I may try and modify to fit my 2 door.
RC Bronco
Rob
Kansas
'22 Ford Bronco, '97 Geo Tracker
myrealname123
Trent
Monterey, CA
'25 Bronco Badlands
MFP2241
WV
2 Door Antimatter Blue BaseSquatch
