Bronco A/C ?
Mals4ever
Appleton Wisconsin
2022 Ford Bronco , 2016 Tahoe PPV
Hoping someone has some insight on this. took delivery of my 2022 Black Diamond in March. The A/C blows cold, never had an issue but ive noticed I get no Drips of condensation of water on the ground after I park. Even in 98 degree temps today. Is this Normal with Newer A/C systems or is a Drain Plugged? There is No moisture under the vehicle at all or on the skid plates or frame.
Techun
Pa
BD, 2.7, MIC, 4dr
Probably just collecting on a bash plate or something. Why are you concerned?
Mals4ever
Mals4ever
Appleton Wisconsin
Ive never had a New Vehicle Not Drip, just concerned if a Drain Tube/Hole isn't functioning. I crawled underneath and everything is Bone dry
mikec426
Russellville, AR
22 4dr Sqtch, '04 Yam FZ1, 22 Versys 1k, 19 Ninja
Just this morning after I got out of the Bronco I heard some sizzling. I guess whatever it drips on is hot. That’s why you don’t see it on the asphalt / concrete.
Ducati1098
If your drain was backed up since delivery, you’d more than likely have some water on the passenger side floor.
Mals4ever
Mals4ever
Appleton Wisconsin
Thanks, maybe thats it, Ive had ZERO issues with mine and Trying to keep it that way LOL
JerryC
Memphis
2022 Bronco
Same thing happened on the wife's Wildtrak.
I've seen condensate puddles under my Badlands. Not as much as I expected, but there it was.
Dlars99
Dan
2023 Black Diamond
I would pull up the floor and check to see if it’s wet underneath. If it is back to the dealer.
WILDcardOD
Patrick
SW Michigan
Rav4, Bronco on the way
Mine definitely condensates and drips here in Michigan. Have a Wildtrak.
Mals4ever
Mals4ever
Appleton Wisconsin
I have the rubberized flooring , I don’t see any trace underneath
Mals4ever
Mals4ever
Appleton Wisconsin
Okay Folks I got the Answer I needed.Stopped at the Dealership, according to a Tech I talked to, If I run the A/C while bringing in Fresh Air I will see the Water dripping, With the Recirculating Air Button on, I wont. He was Spot on, I have water Draining Now. I do appreciate all the Replies.
Dmorty217
Derek
Venice FL
Camery
It collects in your skid plate, hence why you don’t see it on the ground. After driving get out and listen and you can hear the drips hitting something hot.
