Wanted33
Down south in Dixie
Very nice Kelly. Also, I take it the oil filter is under than domed cap on top of the engine just over the main belt pully.
Bronco Don
Don
Rialto, California
Tacoma 4x4
Is that the oil filter right on top in the front? I hope so that would be great just like my Tacoma, oil change in less than five minutes
Thed
Ben
Raleigh, NC
A few thoughts:
-The oil pressure sensor sure is easy to get to, right next to the right valve cover.
-The positioning of the crank speed sensor off of the flexplate is interesting to me. They don't go bad often in the 21st century but removing the trans to replace one may make a few unlucky people sour.
-Electronic wastegates are simpler and more reliable than spring-actuated. Good deal.
-Cooled EGR. Real results for real-world fuel economy gains. Does add in a few more things that needs to be cleaned, though. Hopefully they made it out of stainless steel and not aluminum (ask Cummins how well that worked out for them).
-Electric EGR valves are the way to go and it's nice that it's right on top.
-Plastic oil pans are nice to have, especially if you do your own maintenance.
-Speaking of maintenance, that oil filter location is awesome.
-BIG AND BEEFY oil cooler!
-Is that an EGT sensor by the left turbo that I see? It's a temp sensor of some sort.
-HPFP on the rear of the right head will be a PITA to change out. I like the placement on the 2.3L more (on top of the valve cover).
-Dat sweet, sweet CGI block will be amazing at holding more boost.
-Tiny turbos for quick response, but likely no top end.
-Easy access to coolant thermostat.
-Hopefully the timing chain actually does last the life of the engine, because it looks like it'll be a b!t¢ℌ to change out.
-Whatever that plastic coolant manifold is that's hiding in the valley scares me. You're talking about the removal of the low-pressure and high-pressure fuel systems as well as the intake just to get to it.
Jed
Northern CA
03 4runner V8, 06 Wrangler LJ, 15 Wrangler JKUR...
cute
scary
The engine on the bottom is not the 2.7 just to be clear. That looks to be a German turbo engine, and they are always way more complicated than necessary.
SnowBronco
Canada
Yeahhh it's been mentioned more than numerous times that it's an Audi motor. Buuutttt, reading actual posts seems to be beyond many in this board. That or they just like spreading the bullshit! Who knows! 🙂
ferbm
Matt
Rochester Mn
Couple SUVs, couple clunkers, one sweet ride.
I long for the days I could rebuild the top end in my garage in a weekend, I will be lucky to change the oil on this bitch!
Shoot! Oil will be EASY for most! Suck it right out the dipstick tube with a pump and spin off the filter. You won't even have to get under the truck!!!!!!!
Ope! Here come the guys that need to get EVERY LAST DROP of oil out! Keep er movin'.....
The Bronze
The Bronze
Kelly
1986 Suzuki Samurai, 1967 Ford Bronco, 1993 Turbo Notchback, 2006 Sierra K1500, 2013 Sierra K1500, 2014 Sienna Mini-Van
-The positioning of the crank speed sensor off of the flywheel is interesting to me. They don't go bad often in the 21st century but removing the trans to replace one may make a few unlucky people sour.
Looks like it will pull straight out as it's locate in the block. Now it is REALLY long, so hopefully there isn't a bunch of disassembly around the engine to get it out.
Thed
Ben
Raleigh, NC
I'm not optimistic of that whatsoever with the positioning of the head.
Laddyaddy19
Landon
North Dakota
Nissan Altima, Evo X, F150
Im going to laugh in a few years when people are able to turn the 2.3 into a monster or something crazy that cant be done with the 2.7. I am not saying this is going to happen, but thats how things ironically seem to turn out. Watch the 2.3 somehow become the desired motor long term....
It’s possible but not probable. I have a 2.7 in my f150 and I have also drove a 2.3 explorer for a good chunk of time. I understand the f150 is heavier but even with that said I don’t think it will be a huge difference in power. I simply chose the 2.3 for up front cost savings. I’m actually expecting the 2.7 to get better mpg than the 2.3 in the long run. My truck gets better mpg than that explorer did for some reason.. maybe others could chime in. Both should be fine powerplants. I don’t think it will matter for resale which motor you have.
Stampede.Offroad
SD
junk
....wheres the flux capacitor?
I'm just glad to see a dipstick. So many manufacturer's moving away from allowing the owner to reasonably service their own vehicle is disappointing.
My expectations are low for having one on the trans.
Killed By Death
NC, 'Merica
BMW M2C
A picture speaks louder than words!!! Twin turbos and WAY LESS plumbing, kinda eye catching actually.
Ford Bronco Bronco 2.7L Engine Pictures From Moab IMG_1155
TomH
CT
Ridgeline, 2023 Badlands
I figure these will come in handy later when people are trying to identify where things are located or what certain things are. Since it was a nice sunny day and no engine bay to get in the way, I took these for reference:
Thanks ! Now I’m convinced to buy an extended warranty. Tubes and sensors and wires. Ugh..
revans1009
Ron
PA
2020 Kia Telluride, 2012 Caravan
We'll have a better idea in May when they release estimated delivery time frames. But over 60% of orders are for the 2.7 Ecoboost. So it very well may be a bit of a delay.
I was doing 2.7 BadLands Sasquatch and the second I mentioned squatch and 2.7 the dealer said my order would be "probably be built sometime in summer 2022". There was no hesitation on his behalf at all even when I pressed as to how he would know that until all orders were in and ford made that notification. He was absolute in his response. That was part of the reason I decided to cancel and just wait to see how this may work out in future years.
AHop
Adam
Minnesota
'73 F250 Highboy, '96 Miata M-Edition
Excellent photos, thank you.
For all your F-150 2.7 people, has Ford sorted out the design problems with the plastic oil pans? I believe I read they can crack and leak, what is the full story?
That was fixed years ago. Early 2.7s had an RTV seal and it leaked a ton. In 2018 that was switched out for a composite pan that had a molded rubber gasket. That fixed the leaking problems pretty much completely.
