Broken door bolt during door reinstall!
Crazycactus
Alan
Ohio
1990 F250, 1993 Bronco XLT, 2013 F-150 Platinum
Zinc coating ang galvanized are the same thing, but there is hot dipped and electrochemical.
Gtrekker
Gary
NJ
The factory bolts are not galvanized. It's actually an Epoxy coating such as Magni-565. Galvanized/Zinc plating is a very poor corrosion inhibitor.
Sounds like a good spot for N5000 antisieze.
You can thank me later.... lol
Ground_zero298
Scs michigan
I’m just finishing up my halo install. I had to buy new door brackets which are door and cab, the whole unit. I only used the door brackets. If you need the body bracket shoot me a dm. I can send one and the bolt if you want. I won’t be needing them. They came black from the factory.
