hemiblas
Roger
Aurora, Co
2023 base SAS Bronco, 2018 Rubi JL and JLU
Dont they hold the bronco out as a vehicle capable of that type of driving?
Agreed, I dont think what he did warranted what happened.
balucipher
Balu
Coral Springs, FL
'21 Bronco
They'll claim abuse
Ford dealers love to deny warranty claims.
My Raptor ate it's transmission main harness while offroading once. Limped it to the dealer and they charged me $1600 to replace because they claimed abuse. When I picked it up tech wrote that it was because it was improperly installed from the factory, tried fighting the charges with the Ford customer support line but they didn't budge.
My Raptor's navigation was off by like 30ft (to the east) and they told me it was because I was on 37s
Ended up replacing the GPS antenna myself and it fixed itself. These and a couple of other experiences made me stop buying Ford's until the Bronco pulled me back in
Snydermann
Tim
South East, PA
Samurai, VW Thing, MINI, smart, Astro Van
That inner tie rod looks like a chicken leg.
"Yeah, that looks durable." ~~ no engineer ever
Maybe above the "Lux" package with that sweet Heated Steering Wheel, and 10 speaker sound system should be the "Repair" package, with a 220 volt outlet, for my welder.
CJtoJLU
2021 Jeep Wrangler JLU Rubicon Extreme Recon
They'll claim abuse
I mean I can see a manufacturer claiming hard driving above and beyond normal intended use as a rationale for denying warranty. But the driving in the OP doesn’t seem to fit that bill.
Snacktime
Nate
Sac-a-tomatoes
Bronco, F150
Tire caught grip and jumped forward bending the tie rod/snapped it. Looks like a little to much right pedal, what PSi did you have in the tires? Didn't look like you let enough air out to get grip.
Looks like Hollister Hills?
etmccaus86
Evan
Motor City
'22 BaseSquatch
I agree with you, but logic flies out the window when dealers/ OEs try to justify denying warranty coverage.
MillerAndCheeto
Robin
Calgary, AB
2 Door Cyber Orange Wildtrak Sasquatch
The way it looks, you do a sudden course correction with the steering wheel while you are spinning the tires? I tried rewinding and watching a few times but it happens pretty darn fast. On IFS correcting while heavy on the throttle is a no-no and will lead to tie-rod ends snapping. Lite-Brite has a video where a dude in a hummer does the same thing - heavy on the gas, tires slipping, course correction while still heavy on the pedal and snapped the tie-rod end when the tires grabbed mid-turn. She mentions in the video they see it often with the IFS.
That being said, would a beefier rod work? Hopefully!! Keep us updated on if it's warrantied or not man!
JimL
Pittsburgh PA
2019 Bullitt, 2020 Ford F-150
What the f*ck did they build that piece from, balsa wood? FFS, Ford, you want to push this as a Wrangler competitor, it's got to be able to handle the simple shit like this. Just embarrassing.
Bronco1971
Bob
Lots
If it were me, I would edit that first post to remove the phrase "sent it." That phrase is incompatible with reasonable use I would also remove the video. It's not unreasonable that a dealer or Ford may be aware of these forums. While that course may appear normal to some, the reality is that it's a contrived scenario outside of most norms and will easily be the basis for denying a warranty claim. The forces in an IFS tie rod in those scenarios are quite high, possibly beyond what the engineers anticipated. Though it's more likely that the forces exceed what the rack can handle and the tie rods are much easier to repair.
Finally, we're in the first model year of a new design. There's always something that's beyond what any reasonable engineer can imagine.
MaverickMan
Shane
Definitely sucks and I will totally be looking at that severe duty unit.
However I will admit that those types of obstacles are designed first for knobby mud tires and second to break parts.
Docindahouze
Doc
Cumming, GA
Current: 2016 Ford F-150 King Ranch
That snap reminds of the sound I heard about 18 years ago when my friend blew out his Achilles’ tendon while we were playing a pickup game of soccer. I’ll never forget that sound and the immediate agonizing pain he was in.
