Broaddict 'Table' installed
Icetek
Oeiras Portugal
2012 BMW F21, 2024 Harley Road Glide, 2009 Harley Street Glide
Installed today. Came well packaged to even survive military USPS shipping.
Just installed so have not used it out on the trails but seems really solid. Shaking it after install I did hear one metal-2-metal sound but pulled the top of the upper Molle panel out and it solved that (was hitting just a bit on the left 'wing''.
Installation: Simple but a 2nd hand would make it easier
- would have preferred larger bolts/nuts on the upper mounting points. They seem to be OK and maybe just me but they are tiny.
- Instructions do not mention the foam paint protection. YouTube people talked about 2... I got 3. 2 were twisted in the packaging but still good so put all 3 all.
- the 4 top and 2 bottom T-bolts came semi pre-assembled. But then needed to take them all apart to put the 2nd washers on - seems strange to only semi-assemble but not a major issue.
- As it is brand new do no stop lifting the top shelf to open the 'wings'... I did while holding it on the bolts still not mounted thinking it was as far as it would go but then had to force the 1st 'wing' out. So I scraped the paint a bit there where they rubbed. The top shelf should swing way up and enough to move the 'wings' left and right.
Received several extra washers and 2 extra clasps... not sure if standard or normal.
Looking forward to using it!!!
Ford Bronco Broaddict 'Table' installed 1760809319204-y0
Ford Bronco Broaddict 'Table' installed 1760809339553-ds
Ford Bronco Broaddict 'Table' installed 1760809356126-x7
Ford Bronco Broaddict 'Table' installed 1760809380809-gl
Ford Bronco Broaddict 'Table' installed 1760809398511-g
Ford Bronco Broaddict 'Table' installed 1760809422897-5f
Ford Bronco Broaddict 'Table' installed 1760809454677-xc
Ford Bronco Broaddict 'Table' installed 1760809473578-pt
Ford Bronco Broaddict 'Table' installed 1760809493071-ek
Fastmc25
Fastmc25
East Tennessee
24 Big Bend
Look great.
Does it rattle or make any noise while you’re driving? 🤔
OscarHTX
Houston/TEXAS
I've had the same table, but IAG branded for a couple years now. Super solid and I've used the crap out of it.
Ford Bronco Broaddict 'Table' installed 20231017_180115
Ford Bronco Broaddict 'Table' installed 20231017_175952
Icetek
Oeiras Portugal
Look great.
I'll let you know. Just installed yesterday and I thought I would get out today but things changed.
EasternSierra
Sacramento metro, California, U.S.A.
2025 Bronco Badlands 4-door 7MT, 2023 Ford Transit Connect van
Look great.
Mine makes a little after some hundreds of miles since installation, almost all on pavement. I'm going to have to do some investigation and remediation.
