Brighter Tail Light Bulbs ?
4x4TruckLEDs.com
Adam
Lindenhurst, NY
www.4x4TruckLEDs.com
RClark82
Ryan
2001 F150, 2008 F150, 2021 Bronco
It’s wt21w there’s one on Amazon but I’m looking for good quality bulb.
Good luck. Doesn't exist yet. Sylvania doesn't even recognize the size. Actually the do not even have bronco listed at all.
I highly doubt your going to find a manufacturer difference in a "good" led bulb.
Djd7
Northeast
BD
Both the rear bulb and brake/turn can be swapped to LEDs.
Rear bulb: WT21W - Alla, Diode has this. easy plug and play
Brake/turn: WT21W/7W (buy red, not white) Alla /DD have these, same as F-150
will result in hyperflash on dash, need to use forscan to override
redone17
Cold Spring, NY
2021 Bronco, 2020 Ranger
Oh dang. I didn't realize Diode makes one...they look nicer! I might have to compare.
EDIT: I am only seeing 3157 & 7443 on the Diode site. Link?
Brad Fx
Brad Fx
U.S.A
Jeep Commander
You can't replace the bulbs on the Signature tails (OEM LED). There's nothing to replace
Ah OK, so for Signature tail lights (LED), not a physical plug and play part to swap for something brighter. Thank you.
If you have the signature lights I don't think you have bulbs.
Yep. Looks like there is a solution for those that do have bulbs to get it brighter without pods.
In my case, I suppose I need to just wait a while longer for more bracket options.
Brad Fx
Brad Fx
U.S.A
Jeep Commander
@4x4TruckLEDs.com, any other bracket options you have available yet or have seen aside from my notes below?
  • I don’t really care for the Baja Design reverse light kit, their design for the spare and under bumper.
  • For the zroadz kit, I like the bracket but want to use DD SSC2s or maybe C1s. Not sold on the under bumper location.
  • The DD C2s prototype shown on the Panda SEMA Bronco looks interesting, but still prototype i guess.
  • Rear of a roof rack would work for me, but I’m not sure I’m ready to spend $1,800+ on that and whether it will have garage clearance.
  • Anything else available that I’ve missed?
4x4TruckLEDs.com
Adam
Lindenhurst, NY
well you don’t want it on the spare or under the bumper….. soooo where did you went them mounted?
Brad Fx
Brad Fx
U.S.A
Jeep Commander
Spare is good, I just don’t care for the Baja Design option, so inquiring about other bracket options. Bumper might be OK, but I also have only seen BD and zroadz. I know the aftermarket will open up in time, just trying to understand current or soon to be released options.
4x4TruckLEDs.com
Adam
Lindenhurst, NY
Well Baja is the only company that makes a spare tire mount. Not many options to mount pod lights on the spare tire.
Baja doesn't make the under the bumper kit, that's something we do in-house with our KR Off-Road brackets.
Those are your main options. Honestly folks get worried about lights under the bumper like they are going to rip them off. I come from the Raptor world and i've NEVER seen anybody rip their lights off. That and the lights sit so close to the bumper, you'll destroy your exhaust before you'd ever get close enough to even scratch the lights.
Brad Fx
Brad Fx
U.S.A
Jeep Commander
@4x4TruckLEDs.com are the Diode Dynamics SSC2s compatible with the KR Off-road Bracket? Can you post the link? and a link for any DD wiring harness options? Thank you.
4x4TruckLEDs.com
Adam
Lindenhurst, NY
Yes they would be compatible. But we don't sell our rear brackets alone. We don't have a harness created for the Deutsch connectors, we made our harness for Weatherpacks.
The thing is, there are too many options for us to deal with creating a harness for the SSC2s. It's a 4 pin DT connector and then there could be various options with the red back-light. I don't want to get involved in having people tap into a brake light as well as the reverse circuit so we've opted not to even get involved. Just too much work creating the harness/dealing with instructions that it's not worth the limited profits on those. That's why we stick with what works, our Baja Designs S2 reverse kits.
IF we did a reverse kit for the Diode lights, we would NOT support the back-light feature.
One day we'll create a harness that plugs into the factory tail light harness but until then, we're sticking with what we have. Sorry :(
bigblueboing
Keith
Los Angeles.
Forester
What is the process for the hyper flash override for the stop turn red led bulbs. Is there a relay module to eliminate hyper flash.
604Bronco
British Columbia
www.bronco6g.com
2024 Toyota Tundra TRD Pro
