Break-in period?
PELS82
NA
Reminds me of when i was in my early 20s. Bought a brand new sports car. Driving home with my brother (multi state trip to the dealer)
“hey check the manual for the break in period”
“Im looking. Im looking. Found it! No break in!!!”
Few seconds later im going 115. :ROFLMAO:
i wont be doing that with the Bronco but it was fun
WuNgUn
Ontario Canada
2 door Squatched
Also, don't lug the motor under high loads and low rpm. Especially a boosted engine!
Generally never do this, but particularly under break in.
Agree with the other comments... No steady RPM, allow the motor to spin easily with varying loads, and short trips initially to allow cool down (higher friction and local temp until parts are worn in). The last part may be optional as the truck will likely already have miles on it before delivery.
coolrain
Marcus
NJ - Bergen County
2000 Ford Ranger, 2014 Camaro 1LE
Wow this thread is early
If your going to buy out of state etc just use side roads every couple of hours.... perfect for breaking in
Ride Em Bronco
Al
Pittsburgh, PA
2024 2-door 6-Speed Manual Big Bend Bronco
I went to the 2020 Ford F-150 Owner's Manual and this is the recommended break-in operation:
BREAKING-IN You need to break in new tires for approximately 300 mi (480 km). During this time, your vehicle may exhibit some unusual driving characteristics. Avoid driving too fast during the first 1,000 mi (1,600 km). Vary your speed frequently and change up through the gears early. Do not labor the engine. Do not tow during the first 1,000 miles (1,600 km)
I could interpret that as meaning redline it in the first five gears and take 6th gear only to 100mph (too fast? varying speeds frequently? Changing up through the gears?) - and then take it down to 90 and then to 80 and then to 70 and then to 60 and to a stop and then do it all over again (not laboring the engine?) I am saying this only half jokingly as I really do not understand how Ford wants this truck broken in - rather vague.
Sighlense
Upstate NY
2015 Mustang GT - 2022 Bronco Wildtrak
Never could understand this with a turbo engine. So basically, it's not good to stomp on it from a standstill because that is a "high load, low rpm" situation? I'm personally not a fan of turbo engines, but it's all we got.
RAB123
Goose Bay
2006 RUBICON , 1980 BLAZER , OWNED LIKE 4 OF THE ORIGINAL BRONCOS
take it to a local speed shop and pay for 1 hour of dyno time , then dump the oil , recheck the numbers and your off to the races .
WuNgUn
Ontario Canada
2 door Squatched
Ye
Yeah... Or 10th gear, up hill, pulling a trailer at 1300rpm. BAD!
With the pistons moving so slowly, the combustion cycle puts a LOT of stress on the ring lands and bearings (which aren't bedded in and high-spots polished down)...
A little rpm in these situations is absolutely necessary... But not like 6000rpm or anything!
North7
North Texas
SUV
Long drives at a constant speed are not good for a new engine, if you want to keep it for years and miles to come. While metallurgy and materials have changed in the last 100 years, the basic internal combustion engine has not, crankshaft, rods, bearings, pistons and rings. Treat them right at the start and they will most likely treat you right for the long haul.
There are many examples of the proper engine break-in procedure on the internet, here is one example:
https://www.theenginebuilders.com/break-in-procedure
jsharpe
www.sharpe.com
Prius
Thanks. It was that constant rpm I was wondering about.
Going up and down all those Iowa/Nebraska/etc. mountain passes will help with the constant rpm thing. I think the elevation changes might mike it into the double digits in some places. ;)
CrystalRedTintCoat
BertJ
Bay Area
‘22 Bronco Wildtrak; ‘13 Camaro 1LE
This is straight from the Ranger owners manual. I imagine the Bronco will be the same.
The post above is from 2020. FWIW, in the June 2022 owner's guide it's revised now to say this:
Ford Bronco Break-in period? Screenshot 2022-12-02 at 10.28.03
CrystalRedTintCoat
BertJ
Bay Area
My two cents -- break-in is your decision. I was, and still am, active in the Camaro5 forums and when the 11/12/2013 product group were all waiting for our 1LE's to be built, the same conversation and recommendations ensued:
  • "Break it in"
  • "Don't break it in"
  • "Drive it like you stole it"
  • Those are guidelines
  • Change the oil early
  • Don't change the oil early
  • etc
I maniacally followed the 1500-mile break-in owner's manual instructions. Painful. Long. And, what I'm about to say is NOT factual but just my experience.
My 1LE yielded more horsepower than the guys who "drove it like they stole it".
  • Related to how I broke the car in? Maybe
  • Difference in my town's tuner equipment than others? Maybe
  • Difference in the before-after time of day, ambient temperature in my HP studies vs. "theirs"? Maybe (FWIW, I tested both time at 8am in the same season, same temp, same distance from home to the shop, blah blah blah)
The 1LE was rated at 428 HP. I consistently got more. Others were getting 378, 412, and some even 410 or more like me.
Science? Nah.
But, will I "follow the directions" with the Bronco? You betcha!
YMMV!
Again this is EACH owner's decision. Whatever choice you make is the right choice for YOU.
--CRT (my handle here and the color code of my 1LE)
--Green Machine (the name for my Eruption Green Bronco6g. Shoulda' been my name here!)
EGBadlands
Casey
2021 Ford Bronco Badlands 4 Door
I look at it as the break in practices can't hurt and do as I've always done. Don't think a long road trip will be an issue just vary the throttle often as to not stay in one rpm. 4,000 rpm was what I've stayed under for first 1000 miles.
CrystalRedTintCoat
BertJ
Bay Area
oil change 1K? I'm thinking I will, but haven't decided. Thanks for the insight.
EGBadlands
Casey
I'm considering doing so, we got the service plan because after adding it all up I couldn't do it for less and that's with my labor. Going to use the first oil change free on 1000 miles and let service plan pickup from there.
Lanshark
Little Rock, AR
Infiniti
The highway speed thing is because you're also breaking in every bearing in your drivetrain, you're just trying to avoid excessive, prolonged heat. I know people have a lot of opinions about oil, intervals, and all that. I basically follow the manual unless somebody shows me Blackstone reports to the contrary. And, sometimes they do in the forums. But I haven't seen any oil reports that contradict the owners manual on the 2.7L. And, I'm 100% going to let the 4x4 drivetrain break in before pushing it. That all said, I would rather drive my new car home a 1000 miles than have it ferried or transported by a non-Ford carrier.
