Break-in period?
Ride Em Bronco
Al
Pittsburgh, PA
2024 2-door 6-Speed Manual Big Bend Bronco
All I know is what I was told in the 60's and 70's was to "break a car in the way you want it to run". So with every new car that I got the first thing I did was find an interstate and red line it in every gear and peg it at 130. And the car always ran like a raped ape. ? On the other hand, my friend broke his in according to the manual and his car would run like a dog. ? But maybe car engines are different now.
edgeflyer
2013 FX4
I don't baby new engines and I build race motors including 16,500 rpm superbike engines. That being said, rpm's aren't the key to breakin. Engine load is. Lots of go pedal at low to mid rpm builds the cylinder pressure that will produce the best power and fuel economy. Another less talked about aspect is loong deceleration events from medium high rpm to low rpm to produce high negative pressures in the motor.
kodiakisland
Arkansas
You definitely don't want to let a brand new engine idle at first start up, but I wouldn't red line it either. I don't know how new factory engines are tested at the factory. Rings can seat pretty quick on new engines, so most of that may already be done by the time it goes into the vehicle.
I just think of the things that get really hot when new that won't be as hot when broken in, like hypoid gears, and try to treat them well in the beginning because I know I'll abuse them later.
Spooled
Republic of Texas
Raptor, Model 3
Break it in how you intend to use it. If there's a defect with your new vehicle, you want to find it in my opinion. I work in an engine assembly plant and we run the engines on our dynos harder than 99.9% of customers ever will. Easy break in is a myth with modern machining and assembly processes.
Just my .02
Ajusaf
AJ
VA
I think in the corvette the computer limits its HP to half until the break in period then after that period computer releases the top end speed and full HP output
High Proof
High Proof
Troy
2015 JKU, 2018 Panamera
So basically, if we decide to buy out of state we could come home via some side roads as well as interstate. Just take it somewhat easy and mix it up. All should be good.
Would it be a mistake to throw 37s on before the trip?
edgeflyer
2013 FX4
Yeah, just drive it. Side roads would be good. The motor will eventually break in. I would wait to put the 37's on.
unfortunate
NA
Bought a brand new Toyota in 09 and drove it 6hrs home on the highway.. it's currently at 165k mi and still no issues.. no joke it still drives like new. I did make stops here and there and also very speed on the highway home though. I also did an oil change at 2k and another at 5k(fully synthetic from there on). I'm likely switching to Granger and making another long road trip home for my deal. With the tight tolerance of modern machining these days I think It'll be ok for me and my toyota is my evidence lol.
BroncoBoy22
Laker Land
'11 Mustang GT 5.0
For what it's worth, here is from the user manual, for my wife's 2020 Kia Soul:
No special break-in period is needed. By following a few simple precautions for the first 600 miles you may add to the performance, economy and life of your vehicle.
  • Do not race the engine.
  • While driving, keep your engine speed (rpm) between 2,000 and 4,000.
  • Do not maintain a single speed for long periods of time, either fast or slow. Varying engine speed is needed to properly break-in the engine.
  • Avoid hard stops, except in emergencies, to allow the brakes to seat properly.
  • Don't tow a trailer during the first 1,200 miles of operation.
Don't know if all that applies to other makes of vehicles or the new Bronco.
Owner Manual: No special break-in period is needed
Also the Owner’s Manual: Here’s how you break-in the engine properly...
AKaye
2013 Corvette Grand Sport, 2005 Ford Focus SES
@attworth in post #15 basically spells out what the break in will be at least for the 2.3l. I couldn't imagine thinking I'm more knowledgeable than the engineers who designed and built this engine. ?‍♂
LarryZiegler
Larry
It's 2020, just beat the stuff out of it. No break in oil, no waiting for engine oil to heat up unless you're in freezing temps. Check the manual.
Are you sure that no break in oil is used? I have bought and owned many Honda/Acura vehicles over the last 20 yrs and they do have a special break in oil that is recommended not to be changed for as long as possible for the first oil change. Honda’s only caveat with break in procedures is just not to tow any trailers for the first 1,000 miles. I’ll have to research Ford’s recommendations
JaxGtc
I had my dealer forget to put oil back in during an oil change. I noticed it right away at least.
I had a friend with a garage who did 3 or 4 engines a year under contract with a quick oil change chain. No matter how many reminders and checklists there are, I guess it can still happen. I'm glad you caught yours in time.
EvilJim1971
Jemison Al, 35085, USA
www.instagram.com
2023 Bronco Heritage Edition
I'm flying from Birmingham to St Louis and picking mine up from Laura Ford.
Will be taking secondary roads home for the stop and go, as well as the constantly changing speeds.
Should get me around 600 miles of break in.
LarryZiegler
Larry
I went to the 2020 Ford F-150 Owner's Manual and this is the recommended break-in operation:
BREAKING-IN You need to break in new tires for approximately 300 mi (480 km). During this time, your vehicle may exhibit some unusual driving characteristics. Avoid driving too fast during the first 1,000 mi (1,600 km). Vary your speed frequently and change up through the gears early. Do not labor the engine. Do not tow during the first 1,000 miles (1,600 km)
