Bought 285/70R-17 tires for my base bronco 2 door. Is one inch lift enough?
emuccini
Edward
2 Door Base Bronco 2021 Antimatter Blue
I bought a base Antimatter Blue two door. I bought some 17x9 rims. I love the way they look but the two front tires rub against the crash bar. I dont want to take out the bars. I am going to do a lift kit but these are wide tires (over 11 inches wide). Anyone know if I need 1 inch or two inch lift kit? Is 1 inch enough to prevent the rubbing? Thanks
Tricky Dick
Dick
PNW
www.TD-Distributing.com
I'm surprised they rub. A couple companies make high clearance crash bars. Even if an inch clears them now, they'll rub again once the suspension flexes.
‘21OBX
Ken
90Bronco19
2022 bronco outer banks
Must be the offset of the rims I have 285/70/17 on my stock OBX sale base suspension you have. But on badlands rims no rubbing. Do they run on the rear bars or front? Rear are less than 5 min to remove. Fronts with the plastic bumper yeah they are a bit more work.
