Both fobs stopped working -- any ideas?
bomchet
Bom
northern va
2014 dodge durango
Can start the Bronco just fine when I'm in it, but no dice on any of the buttons away from it.
Could I have accidentilly locked its use somehow? Only had it for two weeks, can't imagine both fobs would've gone bad that fast. Thoughts?
Thanks in advance. (pretty sure I did something dumb.)
bomchet
Bom
northern va
2014 dodge durango
Update -- the remote start feature works. But nada on the unlock or lock buttons.
jakej
Jake
2016 F150
Did your dealer install one of those (stupid) security systems that they try to charge you a bunch of money for? Mine did and it caused some issues with my keyfob door locking when I disabled it (since I refused to pay for it). Might be worth checking that if they installed one...
bomchet
Bom
northern va
2014 dodge durango
Don’t believe so… drives just fine, remote start works, worked for last two weeks, since I got it.
wondering if I just hit a key combo that locked it out. Reading the manual, but no such luck so far.
PSUTE
Western Maryland
Sierra
Allegedly, if you pull the liner out of the center console, there is a spot for the fob Have no idea of the magic it can do. May be worth a try...
bomchet
Bom
northern va
2014 dodge durango
Thanks, but the manual says that’s just to start the vehicle if the fob’s battery is dead. Both of my fobs just don’t lock/unlock.
MillerAndCheeto
Robin
Calgary, AB
2 Door Cyber Orange Wildtrak Sasquatch
Try looking in your settings, you may have disabled something by accident. Or.... take it to the dealer. Have you made an appointment already?
bomchet
Bom
northern va
2014 dodge durango
I did confirm neither fob has become a mykey. Haven’t called the dealer yet.
TrailRaider
Mr. G
So. Cal
Focus ST, Mitsubishi Montero, Bronco Badlands
Do you have a door keypad? I read somewhere that if you use the keypad to lock it, your remotes are disabled until you unlock it with the keypad. Cannot verify that rumor though.
bomchet
Bom
northern va
2014 dodge durango
I do have the keypad - I’ll mess around with that, thanks.
RHeinz
Ric
Houston, TX
Just tried that. Unlocked the Bronco with the fob from the house. Left the key fob in the house and then locked the Bronco using the keypad. Went back into the house and was able to unlock the Bronco using the fob.
RHeinz
Ric
Houston, TX
Also, I use the key pad a lot and have never run into issues with the fob not working.
PatsBronco
Patrick
Murfreesboro
72 Bronco 16 Super Duty
I know a lot of the guys hate the key pads but I haven’t had a Ford anything in the last 15+ years that didn’t have one. I use it all the time.
bomchet
Bom
northern va
2014 dodge durango
So that might be it. Holding the 7-8 and 9-0 doesn’t lock it, regardless of whether the fob is near or not.
Dads_bronze_bronco
08 JKUR / x_x 00 TJ x_x
I am sure you checked this but did you try changing the battery?
