Borla ATAK 2.3 manual.
bigblueboing
Keith
Los Angeles.
Forester
Just installed the borla exhaust replacing the outlaw straight pipe.
really really happy with the sound and look.
any suggestions on aligning the outputs since the are off a little bit.
Ford Bronco Borla ATAK 2.3 manual. 9A8BF1E2-EF60-483C-BEB1-711D2A5F1D7B
Wazznme
Chugiak, Alaska
BMW X7, 2012 F350, 1971 Chevy K10
Love the Borla exhaust, I went with the S-Type on my 2.7 and it sounds amazing. I had the same problem as you where the driver side sat up higher, tried multiple different things to align and finally ending by this, https://a.co/d/9oRqYnr, and it worked perfectly. Installed it on driver side.
bigblueboing
bigblueboing
Keith
Los Angeles.
Forester
That’s very helpful ty.
Slick85
Richard
Austin, TX
How does it sound? Is it deep for the 2.3? If you could post a vid or sounds clip much appreciated.
BigHoof
PA
Ram 2500
Just put mine on today. Do you have any issue with the plastic by the plate and heat from the tip? I got mine even but can barely get a finger between the tip and the metal part of the bumper. Saw the post above with the longer rubber hangar but then would need another for the passenger side since they are currently even.
Loughmasta
Kevin
Manayunk, PA
BigHoof
PA
Ram 2500
I had to switch out the rubber hangars. The exhaust tips would rattle off the bottom of the bumper when I started out being so close.
Dadsquatch
Brad
Chandler, AZ
2022 Ford Bronco
I have the S-Type for my 2.7L and love it. I also had the same problem with the tips not being even and ultimately was able to finagle it enough to get mine level. Try loosening the bolt where the Borla system meets the factory pipe, grab the whole Borla system and twist it to get them even. Then tighten the bolt back down. This worked for me, but both of my rubber hangers are at an angle, but not causing any issue and zero wobble.
Ford Bronco Borla ATAK 2.3 manual. IMG_1260
