Bore Size?
DUSTYcazOREGON
Craig
Do we know the wheel center bore size / the spigot size of our BRONCOS in mm ? Not a guess or presuming it is the same as the Ranger....an actual confirmation. Thank you.
Ford Bronco Bore Size? 1612544301840
ZackDanger
Z
Massachusetts
2021 Toyota 4Runner
I thought someone measured it with their calipers in the factory a while back... maybe it was just the ask that never got done?
DUSTYcazOREGON
DUSTYcazOREGON
Craig
I did use the search feature. Questions about it and one guy said it was 93.1 "same as the Ranger"...but I do not know if that was an assumption or a fact. Would be nice to get factory/employee confirmation on that.
KH_59
Kevin
pearland tx 77584
F-150
ZackDanger
Z
Massachusetts
2021 Toyota 4Runner
Well.. how's this:
https://www.bronco6g.com/forum/threads/⚙-2021-bronco-oem-factory-rims-wheels-specs-sizes-offsets-⚙.11893/
Here is a picture from the factory of the 17" steel wheels... exact same numbers as the Ranger steel wheels... Makes me think that "same as the Ranger" is a safe assumption!
::EDIT:: Link in post above to Levine confirming that steelies are shared across platforms.
Ford Bronco Bore Size? 2021 Bronco - Factory Rims _ Wheels Specs 4
Ford Bronco Bore Size? Ranger Steel Wheel Black
DUSTYcazOREGON
DUSTYcazOREGON
Craig
Well.. how's this:
Hopefully you are correct....but the number is not the same, unless I am wrong. One has a "Z" while the other a "C".
DUSTYcazOREGON
DUSTYcazOREGON
Craig
ZackDanger
Z
Massachusetts
2021 Toyota 4Runner
My understanding is that figure in the part number only refers to what "division" that part number came from or something or other.
Furthermore there are subsequent part numbers listed on the Ranger wheel that match exactly what the Bronco wheel has stamped on it.
