Bluetti Charger 1
redone17
Cold Spring, NY
2021 Bronco, 2020 Ranger
Does the Charger 1 back-charge the battery? Essentially acting like a trickle charger. I thought that was a cool feature.
Harliquin74
Los Angles, CA
2024 Bad Lands
I don't think so, if the charger 2 is that might be a good reason to get it.
Murg
Washington
2005 Jeep TJ
Finally got a break in the rain. Found the perfect spot behind the drivers side cargo area panel. Works like a charm. Put in an Anderson 45 port in the small removable panel. Will attach pics in a bit. Added a headless HAM radio in the glovebix area with the mountains to metal mount. Now to wire up the starling then I think most of the wiring stuff will be done. 😂
I thought about that spot, but it doesn’t meet the airflow requirements (about 7” space around all sides) in the document.
Harliquin74
Los Angles, CA
2024 Bad Lands
I've had it in and connected to my AC180T for over 2 weeks now no issues what so so ever.
Murg
Washington
2005 Jeep TJ
I am most likely going to move it there. How are you dealing with the circuit breaker on/off? Or do you just leave it on all the time? I currently switch it off when not using it. Looks like the Charger2 removes the break, adds a fuse. and might have a better on/off feature? but more power.. more heat..
Harliquin74
Los Angles, CA
2024 Bad Lands
I just leave it on. But I am only pulling 27v from the car so as not to cause issues with the alternator.
Bird Dog Off Road
Jody
Phoenix, AZ
www.youtube.com
Does it matter if the negative is mounted to the negative battery post or another ground with the BMS? Have a charger1 I want install this weekend.
