Bluetti Charger 1
Harliquin74
Los Angles, CA
2024 Bad Lands
So I got a Bluetti AC 180t and a multi-cooler with a Charger 1. Trying to mount the charger 1 somewhere I can run a line to the cargo area where I mounted an Anderson connector on the drivers side panel. Problem is Carger one is too thick to mount behind that panel and won't fit under the back seats (4 door badlands). Any help on where to mount it?
Harliquin74
Los Angles, CA
2024 Bad Lands
Does it have any issues with the hard top on? It' pretty thick.
Harliquin74
Los Angles, CA
2024 Bad Lands
Good to know. Not sure if I want to do molly panels. Was thinking I might try to run it from the tray under the cargo floor.
TXAstro
Everglades
Trevor
Bronco Everglades
Everglades
I receive charger one today and will install with inline fuse. Any issues fitting the cable in the door track along the floor? did you lower the volts in the app to 40 for the alternator?
Harliquin74
Los Angles, CA
2024 Bad Lands
Been busy with work. On holiday break and off course it's pouring down rain, so haven't installed it yet but hopefully this week.
Harliquin74
Los Angles, CA
2024 Bad Lands
Finally got a break in the rain. Found the perfect spot behind the drivers side cargo area panel. Works like a charm. Put in an Anderson 45 port in the small removable panel. Will attach pics in a bit. Added a headless HAM radio in the glovebix area with the mountains to metal mount. Now to wire up the starling then I think most of the wiring stuff will be done. 😂
Ford Bronco Bluetti Charger 1 20251227_123727
RustysBronco
Matt "Rusty" R.
Jupiter, FL
www.instagram.com
2022 Ford Bronco Badlands Sasquatch
Clean spot.
redone17
Cold Spring, NY
2021 Bronco, 2020 Ranger
I guess this makes more sense than running the ARB socket I had in my 2021. Same effort. Better/safer results.
Why is the provided fuse on the charger side and not the battery?
Harliquin74
Los Angles, CA
2024 Bad Lands
Not sure about the position of the breaker but realisticly at 12v/30a using 6AWG wire I don't see an issue. The breaker should trip well before the wire has any issues.
redone17
Cold Spring, NY
Looks like Bluetti is about to launch Charger 2. Glad I held off buying one during T-day/Christmas sales.
Harliquin74
Los Angles, CA
2024 Bad Lands
Wonder what the differances are charger 1 works great.
redone17
Cold Spring, NY
Harliquin74
Los Angles, CA
2024 Bad Lands
Interesting.... not sure if it worth trying to figure out how to wire the solor blankets to be removable when not in use, Right now I just have 2x250W blankets with a splitter that connect to the AC180T via the solar port (easy plug in when needed unplug when not).
