Block heater remote plug
FortMacGuy
Fort McMurray
2024 Bronco
Ford had a real brain fart where they hid the block heater cord. I made a temporary block heater relocation bracket and extension.
I used a NOCO 16" extension (lengthened by 12 inches).
A piece of aluminum road sign.
I will be making a new mount in the spring because the fog light pocket will be filled with lighting.
Ford Bronco Block heater remote plug 20250105_123317
Ford Bronco Block heater remote plug 20250105_123334
TJP249
Tom
Davidsonville, Maryland
2000 F350 SD 7.3 PSD, 2023 F350 SD 6.7 PSD, 2014 Ford Explorer PIU
FortMacGuy
FortMacGuy
Fort McMurray
2024 Bronco
I just ordered one of these for my 23 Super Duty last night!. Plug is very obscured due to to grill guard & winch. I found this mounting plate on Etsy and was worth it for the time I would have into fabricating one:
https://www.etsy.com/listing/129072...uMJd-VVaxS6RTbTmNIzWT2ECYjPpkrMRoCDf8QAvD_BwE
I did order the block heater for my Bronco, but probably won't need it too often if at all.
I find it odd that NOCO only sells the 16" and a 6' extension. It sure would be nice if they had a 36" flavor.
MNBigfoot
MN
I just unhooked like 5 clips and the strung the OEM cord out the same spot as you, no extension needed.
FortMacGuy
FortMacGuy
Fort McMurray
2024 Bronco
uh, that's a great idea!
I have to say I didn't think out the rerouting option.:confused:
I might go that route next winter...
MNBigfoot
MN
yours looks much cleaner, I like it, mines held in place with a zip tie.
TJP249
Tom
I went with the dual 18", one for the block heater, and one for a GENIUS2D trickle charger.
RNC
Roger
Ohio
2022 Ford Bronco
I ordered it with my 22 Basesquatch. A $100.00 upgrade at the time, so I figured; why not? The placement of the connection does seem like an afterthought.
Montana Bronco
Montana
Chevy
Huh ?
I use mine all the time, no problem at all with stock setup/location.
FortMacGuy
FortMacGuy
Fort McMurray
2024 Bronco
Huh ?
The stock location is not so wife friendly at - 30.
Darn cold to be fumbling around with hoods and cords.
To each his own for sure.
michelle227
michelle
North Texas/South Canada
Badlands 2dr 7spd/ Mercury Grand Marquis/ Jaguar X-Type/ Fiat Spider
Yeah...I picked mine up earlier and expected it to be around the number like with mu 2000 F350 PSD. Nope...got to open the hood and *woop* there it is.
.Much prefer easier access than having to open the hood...
